Ibiza1986 wrote: |
| Weld a metal sheet behind it, line it from the inside, and then apply fine filler... otherwise, it won't last. |
Welding is essential; it's a must. Soldering is a different matter. The door is a large, flat sheet of metal. What do you think will happen if you hold a torch to it to solder? Right, everything will warp.
Therefore, I prefer aluminum filler. Even my painter says it's the modern way of applying a protective coating. It's also a metal, so it's quite compatible with the material of the door, and it's applied without heat. Another advantage: aluminum filler can be sanded and painted directly. With tin, you'll always need to apply a final layer of fine filler afterwards.
My tip: Weld carefully, meaning slowly, and allow enough time for the metal to cool so that it distorts as little as possible. Then, you'll only need to apply a thin layer of filler. Use aluminum filler.
Another option, if it's a 3-door model: Get the doors from a Rallye Golf; they didn't have any trim pieces, even though they had one-piece windows. Then have fun searching! *laugh*
