Turbo "pulsates", power brake booster failing
ananga
Post12-10-2009, 23:21    Subject: Turbo "pulsates", power brake booster failing Quote
Hello everyone, I'm new here and I have a question or a problem.
I've already tried using search engines...
I'm currently working on a 1995 Passat TDI with 66 kW. The problem:
"Starting around 3500 RPM, the turbocharger begins to surge. This results in a pulsating effect: acceleration, then a drop in power, followed by acceleration again, then another drop, and so on." I've already inspected the vacuum hoses, but I didn't find anything.
2. The braking performance is okay the first time you brake. However, if you press the brake pedal a few more times, the braking pressure decreases. The pedal pressure becomes harder, meaning the vacuum booster no longer provides vacuum assistance. I've already checked the hoses and U-shaped pipes.
Result: The hose that runs from the vacuum pump towards the air filter was not properly connected on the air filter side. I reconnected it, but there was no improvement!
Does anyone have a tip for me?
Okay, here's the translation:
"Something else." The internal components of the intercooler seem quite oily - but I assume that's normal, OR IS IT???
Thanks in advance for your information.
Hi Manu!
Karma: +438 / -0   Thank you, like it!
Post13-10-2009, 13:53    Subject: Re: Turbo "pulsating", power steering failing Quote
ananga wrote:
(...) in other words, the BKV no longer has any negative pressure. Did someone give me a tip there?
Connect the vacuum hand pump with the pressure gauge, create a vacuum, and observe whether it drops. Possibly while wiggling connections, etc.
If no leaks can be detected, the pump must be inspected (using a vacuum gauge, observing the rate at which the vacuum builds up).
However, I strongly suspect there is a leak, as the necessary vacuum needs to be achieved first.
ananga wrote:
The internal components of the intercooler are quite oily - but I suppose that might be normal OR????
Yes, that's normal.
Please observe the forum rules; a question mark is sufficient.
Guste.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unterdruckschlauch zum Bremskraftverstärker "Porös... Diesel Engine Technology
No new posts Turbo vom PD an "normalen" TDI z.B. AFN Diesel Engine Technology
No new posts Passat 08/01 MKB "AVF" GKB "EYF" Getrieb Diesel Engine Technology
No new posts Driving Too Dumb? A Brave New World Diesel Engine Technology
