Antenna Connectors: Buy Single Units.
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Octavia_4x4
Post15-11-2009, 22:28    Subject: Antenna Connectors: Buy Single Units. Quote
I specifically need crimp connectors for:
FAKRA => RAKU (a standard radio antenna connector, not the ISO connector on the radio).
FAKRA => SMB (telephone)
"I recently bought an antenna from a Golf V for my Ibiza, and it's a combination of a shark fin and a standard antenna... My car has the standard RAKU connector at the top of the rear window, and there's an adapter from VW for around €16 to connect it. However, I'd prefer a simple snap-on connector, as it's likely cheaper... I'll have to reroute the antenna cable for the phone anyway, so that's a secondary concern."
Do you know where you can get the individual connectors, and whether it's even possible to buy them separately? I've already searched through all of our ordering systems, and I can't find them.
Greetings.
Georg.
Translated on 02-09-2026, 0:38.
michiglaser
2007 Audi A4 Avant
Post15-11-2009, 23:28    Subject: Antenna Connectors: Buy Single Units. Quote
I cut off both connectors from a B4 Passat belonging to a neighbor and soldered the wires together.
It's a bit of a makeshift job – first, the inner conductor was soldered, then insulated, the outer conductor was soldered with copper wires, and the whole thing was completely shielded again with aluminum foil, and then insulated again. However, it has been working perfectly for years without any problems and with excellent reception.
The cheapest method is if the antenna or its base doesn't need to be removed again in the near future.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 02-09-2026, 0:39.
Octavia_4x4
Post15-11-2009, 23:37    Subject: Antenna Connectors: Buy Single Units. Quote
*cough*
"Yes, I had considered that as a temporary solution, but I'm somehow not keen on doing something so "makeshift"... However, I've now even found the original VW connectors individually. The problem is, I'm not sure how well they will fit onto the cable until I place a "test order." It would be the cheapest option at 2€ per connector, as I only need 2 for the antenna, and a 4-meter cable for the hands-free system control unit... so that I can finally have "reception everywhere"."
The reason for the entire replacement is that the threads have stripped for the second time (yes, this poorly designed retractable antenna). The antenna often folds down while driving, and it also constantly makes noise, which is increasingly annoying to me.
She had already replaced it a year ago, but now I'm fed up... Luckily, the new one no longer has that pointless hinge... Whoever knows how to do it can bypass the so-called "anti-theft device" even with the hinge... icon_biggrin.gif
Translated on 02-09-2026, 0:41.
Octavia_4x4
Post19-11-2009, 0:50    Subject: Antenna Connectors: Buy Single Units. Quote
"What a mess... VW sells the connector housings, but not the sockets inside them... So today, all I could do was cut and solder them together - it's okay in the end, I have excellent reception, and I even managed to shield it, so whatever, it works... And finally, I have phone service via antenna."
Translated on 02-09-2026, 0:43.
No new posts Motor Control Unit Connectors: Order Now! On-Board Diagnostics (OBD)
No new posts Batteriestopfen einzeln kaufen Diesel Engine Technology
This topic is locked, you cannot edit or reply. Pumpe Düse Düsen einzeln wechseln ? Diesel Engine Technology
No new posts Delete Errors Individually: A Step-by-Step Guide On-Board Diagnostics (OBD)
