LMM Failure: Troubleshooting & Repair Guide
slg60
Post23-11-2009, 22:59    Subject: LMM Failure: Troubleshooting & Repair Guide Quote
Hello! Can anyone tell me where I can find the information using VAG-COM to see if my mass airflow sensor (MAF) is still functioning correctly?
I've had the impression for a few weeks now that my ARL (presumably referring to a specific system or device) seems to be weakening.
Is there a material data sheet (MDS) available for the LMM? Thank you in advance!
Translated on 20-10-2026, 1:27.
Klausel
Post23-11-2009, 23:50    Subject: LMM Failure: Troubleshooting & Repair Guide Quote
MWB 3 provides the target and actual values, and indicates whether the actual values are still within acceptable limits.
You can find out if something is good enough in the MWB 8.
It's best to read up on this here.
/viewtopic.php?t=3322
Best regards, Klaus.
Translated on 20-10-2026, 1:28.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM failure? On-Board Diagnostics (OBD)
No new posts MKB: ARL PDE failure? Upload
No new posts MFA malfunction On-Board Diagnostics (OBD)
No new posts Defective STG 028 906 021 AT - Replacement On-Board Diagnostics (OBD)
