Can someone help with this error code?
01038 - Central locking, thermal protection.
000 - - - Sporadic
Is there something wrong with it? Perhaps the vehicle was once in a paint booth and the comfort control unit got slightly too hot?
Tuesday, November 24, 2009, 2:23:38 PM: 64629
VCDS version: RKS 908.1
Data as of: 2009102.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BĂ€umen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag fĂŒr einen Spaziergang."
Vehicle type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
Vehicle Identification Number (VIN): WAUZZZ8Pxxxxxxxx
Mileage: 27,950 km
01-Motor -- Status: OK 0000
03-Brakes -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate Control/Heating -- Status: OK 0000
09-Onboard network -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
Immobilizer system -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
Steering assist - Status: OK 0000.
46-Comfort System -- Status: Error 0010.
47-Sound System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
Door 72, electric hinge, right side -- Status: OK 0000.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Feld und lÀsst das Gras sanft wiegen. Es ist ein wunderschöner Tag."
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze blows through the field, causing the grass to sway softly. It's a beautiful day.
Address 01: Engine (CBA) File name: RKS\03L-906-022-CBA.clb
Part number SW: 03L 906 022 LS, HW: 03L 906 022 BQ.
Component: R4 2.0L EDC G000SG 3610.
Revision: 13H01--- Serial Number: AUX7Z0H9FN70PX
Encoding: 0000072
Operating number: WSC 00046 412 00000
No errors found.
Readiness: 0 0 0 0 0
Address 03: Brakes (-----)
Label file: RKS\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 AD, HW: 1K0 907 379 AD.
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Encoding: 11424012092300FA881302E7901900423800
Operating number: WSC 00046 412 16384
No errors found.
Address 08: Climate Control/Heating Label file: RKS\8P0-820-043.lbl
Part number SW: 8P0 820 043 BH Hardware number: 8P0 820 043 BH
Component: Climate Control System H09 0100.
Revision: 000192 Serial Number: 8P0820043BH
Operating number: WSC 00000 000 00000
No errors found.
Address 09: Body Control Module
Label file: RKS\8P0-907-279-30-H.lbl
Part number SW: 8P0 907 279 N, Hardware: 8P0 907 279 N.
Component: Onboard network module H54 2801.
Revision: 00H54000 Serial Number: 00000008928540
Encoding: 11A82F8190141380EF00001C0000000000094E056401040300A800000000
Operating number: WSC 00046 412 49152
Part number: 8P1 955 119 F
Component: Wiper blade AU350 H10 0040.
Encoding: 00056595
No errors found.
Address 15: Airbag (J234)
Label file: RKS\8P0-959-655-10.clb
Part number SW: 8P0 959 655 J, Part number HW: 8P0 959 655 J.
Component: Airbag AU1042 H06 0090
Revision: -------- Serial Number: 003000000000
Encoding: 303142383038303030354A55304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
No errors found.
Address 16: Steering wheel
Label file: RKS\8P0-953-549-F.lbl
Part number SW: 8P0 953 549 F, Hardware: 8P0 953 549 F.
Component: J0527 H36 0070
Coding: 0000042
Operating number: WSC 00046 412 802816
No errors found.
Address 17: Combination instrument
Label file: 8P0-920-xxx-17-MY8.clb
Part number SW: 8P0 920 931 S, Hardware: 8P0 920 931 S.
Bauteil: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial Number: 2249H006039976
Coding: 0004028
Operating number: WSC 31127 141 11685.
No errors found.
Address 19: CAN Gateway
Label file: RKS\1K0-907-530.lbl
Part number SW: 1K0 907 530 Q, HW: 1K0 907 951.
Component: J533__Gateway H16 0202
Revision: H16 Serial Number: 2700K0871783AD
Encoding: E9807F061002022102
Operating number: WSC 00046 412 106496
No errors found.
Address 25: Immobilizer
Label file: RKS\1K0-920-xxx-25.lbl
Part number SW: 8P0 920 931 S, HW: 8P0 920 931 S.
Revision: D0H18006 Serial Number: AUX7Z0H9FN70PX
No errors found.
Address 42: Door electric control unit
Label file: 8P0-959-801-MIN3.lbl
Part number SW: 8P0 959 801 K, Part number HW: 8P0 959 801 K.
Component: Door Seal H03 0060
Encoding: 0000148
No errors found.
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x.lbl
Part number: 1K0 909 144 C
Component: EPS_ZFLS, Class 232, Part Number 2301.
Revision: 00H15000
Operating number: WSC 02069 000 90108
No errors found.
Address 46: Comfort System
Label file: RKS\8P0-959-433.lbl
Part number: 8P0 959 433 L
Component: KSG H11 0080
Encoding: 1880200002186D0985054C8F0167
Component: Sounder, not mounted.
Component: NGS, not mounted.
Component: IRUE, not mounted.
"One error found:"
000 - - - Sporadic
Address 47: Soundsystem Label file: RKS\8Px-035-382.lbl
Part number SW: 8P4 035 382 D, Part number HW: 8P4 035 382 D.
Component: AB2 SUBWOOFER BOX H06 0180
Revision: 00005 Serial Number: 30674802902117
No errors found.
Address 52: Door electric, passenger side. Label file: Diversion failed!
Part number SW: 8P0 959 802 K, HW: 8P0 959 802 K.
Encoding: 0000148
No errors found.
Address 56: Radio
Label file: RKS\8J0-035-1xx-56.lbl
Part number SW: 8P0 035 186 P, Hardware: 8P0 035 186 P.
Component: R Concert2+ H03 0270
Revision: 00H03000 Serial Number: AUZ1Z3H3475095
Encoding: 0110211
No errors found.
Address 62: Door electrics, left/right. Label file: RKS\8P4-959-801.lbl
Part number SW: 8P4 959 801 E. Part number HW: 8P4 959 801 E.
Component: Door Module H04 0040
Coding: 0000144
Operating number: WSC 00046 412 1012544
No errors found.
Address 72: Door electric, high, right. Label file: RKS\8P4-959-802.lbl
Part number SW: 8P4 959 802 E. Part number HW: 8P4 959 802 E.
Coding: 0000144
No errors found.
End.
Translated on 15-07-2026, 11:26.
