Parkbremse Audi A6 mit VCDS schliessen | Posts 16+
Go to page: Previous  1, 2
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post17-12-2009, 21:03    Subject: Quote
In the settings area, after testing the USB interface, the following appears:
Update the USB library/driver version to 03.01.18 / 02.04.18!
Initially, I couldn't access the A6 using the USB port that I normally use. Then, I went to the other side of the laptop and logged in there. It probably would have worked on the first USB port as well, if I had logged in again using that port.
"However, this issue only started appearing with version 908.1; previously, it also occurred with the A6."
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 05-10-2026, 11:50.
Post17-12-2009, 21:24    Subject: Quote
Regarding the USB port issue, it's normal depending on the computer. You can either install drivers for all the devices you use or always use the same USB port.
Translated on 05-10-2026, 11:51.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post17-12-2009, 21:38    Subject: Quote
Okay, but the driver error message appears on all USB ports, at least now without the vehicle in the "dry run" mode.
Post18-12-2009, 9:38    Subject: Quote
Hi Klaus,
However, Ross-Tech provides a note regarding driver versions:
The USB drivers shipped with some previous Releases reported an incorrect version -- much higher than it should have been. When you install the new drivers that come with this version, Windows will probably complain that they are older than the ones which are already installed. You must answer "Yes" when asked if you want to replace the files anyway. Previous versions of VCDS may also complain that the new drivers are outdated. This can and should be ignored.
So, just click "yes, that's fine" icon_smile.gif.
PS: You have a private message.
Translated on 05-10-2026, 11:52.
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo 3.0: AGR Valve Replacement Guide Diesel Engine Technology
No new posts VCDS for Audi A8 4H: Installation & Setup On-Board Diagnostics (OBD)
No new posts VCDS HEX-V2 for Audi Q4 2023 On-Board Diagnostics (OBD)
No new posts Audi R8 Gen 2 Steering Wheel Alignment with VCDS On-Board Diagnostics (OBD)
