Timing Belt Replacement VW Passat 1.9 TDI
Pölscheich
Post06-01-2010, 18:03    Subject: Timing Belt Replacement VW Passat 1.9 TDI Quote
Hi.
What's the issue with this vehicle?
Volkswagen Passat 3B, 115 horsepower, 1.9 TDI PD engine, AJM code.
Here's the translation:
"What should be considered during a timing belt replacement, or what is different compared to what is described in the two articles (since it's a lengthwise installation...)"
Is there perhaps an instruction manual for this? Do all the coolers need to be removed (it's quite cramped in there)?
Cooler and belt drive?
We will be replacing the water pump. Besides the timing belt, tensioner pulley, and idler pulley, are there any other new parts needed? Can anyone recommend a good quality replacement parts kit and a decent tool set?
Sure, no problem. Here's the translation:
"Thank you in advance."
Best regards, Matze.
Translated on 27-07-2026, 9:44.
Back to top Profile PM Email
charlyfirpo
2013 Volkswagen Golf
Post06-01-2010, 19:44    Subject: Timing Belt Replacement VW Passat 1.9 TDI Quote
Hello.
What do you need? Cable harness and wiring tools. You can find them cheaply on online marketplaces. I have some, and they work great. VW has a tool (VAG 3369) to put the front of the car in a service position. I bought two M8x160 slotted screws and two rubber door stoppers from the hardware store. You attach the door stoppers to the slotted screws, and they act as softer end stops.
The space between the radiator and the engine is sufficient when in the service position. Remove the fan blade, and there's plenty of room then.
That's pretty much it. Standard tools for VAG vehicles are assumed.
Spare parts: VW. I only use genuine VW parts for timing belts.
Instructions available upon request via private message.
Golf 4 GTI TDI, ARL Serie 346031 Km
Webasto Thermo Top E
15.02.2013 -> Golf 6 GTD DSG CFGB/NLN, TT-V+T91R
21.03.2016 -> Golf 7 R, Limestonegrey, 19", Voll...
Translated on 27-07-2026, 9:46.
pax
Avatar-pax
2000 Volkswagen Passat
Post06-01-2010, 21:01    Subject: Timing Belt Replacement VW Passat 1.9 TDI Quote
I tried this out on my ATJ for the first time last summer, and it worked without any real problems. You can find some pictures here:
http://www-user.tu-chemnitz.de/~pax/Passat/ZR/
I completely removed or shifted the front panel aside so I could clearly see what I was doing. This is certainly not necessary if you have enough experience. The crankshaft stop can easily be misaligned when pushed in – but with the front completely disassembled, you can see that very well.
Important tip (I think I saw this in the forum before): After setting the 4mm and rotating the motor for a few minutes, wait before checking the adjustment value again.
I got some of the parts from the Original VW Parts shop (AHW), but I still had to cut a piece off the water pump.
Instructions can be found in the "Etzold" or "Erwin" manuals.
I also replaced the tensioner bolt for the idler pulley. Depending on their condition, you may also need to replace the timing belt tensioner and the serpentine belt tensioner.
Bye.
peace
Translated on 27-07-2026, 9:49.
charlyfirpo
Post06-01-2010, 22:12    Subject: Timing Belt Replacement VW Passat 1.9 TDI Quote
Hello.
"@pax, great pictures! They really help visualize things. Seeing them again just reminded me that the viscous coupling of the fan wheel was in the way when I tried to unscrew the tensioner. It has a hex screw that you can feel if you reach behind the coupling. The screw rotates along with the fan."
It looks like you need to unscrew a Torx screw, probably a 5 or 6 mm size, while holding the clutch in place.
As I said, everything is attached to the front.
The clearance of approximately 4mm is correct when the engine is cold, and it needs to be adjusted by turning it in the direction of rotation. Additionally, there must be at least 1mm of clearance when the engine is warm.
Under no circumstances should the wrench be tightened.
Translated on 27-07-2026, 9:51.
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts Zahnriemenwechsel Passat MKB AVB Diesel Engine Technology
No new posts Timing Belt Replacement VW Passat TDI Diesel Engine Technology
No new posts Timing Belt Replacement VW Passat 35i Diesel Engine Technology
No new posts Questions and notes regarding the timing belt replacement... Diesel Engine Technology
