Wiring Repair: ZV Pump Connector Fix
wbuchi82
Karma: +9 / -0   Thank you, like it!
Post10-01-2010, 20:25    Subject: Wiring Repair: ZV Pump Connector Fix Quote
Hello!
After many kilometers of trouble-free driving with my A3, I have to reach out with a question again...
I've actually already found the error itself, but I'm still having a problem with the actual repair.
"My central locking system completely failed a few days ago, and after a long search, I found a completely corroded cable at the connector to the central locking pump. Now I don't know how to permanently and reliably reattach the cable to the corresponding contact... I've attached a photo of the connector and the damaged cable."
Is it possible to disassemble the connector so I can solder the cable back to the correct contact, or do I need to assemble a new connector?
Temporarily, I stripped a section of the cable and attached it to the contact with tape... but that probably won't last icon_wink.gif.
Does anyone know anything about this?
 File size:  108.5 KB
 Viewed:  11595 times
Audi A3 Ambition, Bj.02, ASZ - SoftwareTuning 160PS
Multimedia-CarPC 2,4GHz - 1GB RAM - 300GB HDD - 8" Tochscreen
Translated on 03-09-2026, 13:58.
Back to top Profile PM Email
Post10-01-2010, 23:45    Subject: Wiring Repair: ZV Pump Connector Fix Quote
My solution would be:
- buy a new plug (~3€)
- Remove usable pins from the circuit board.
- Replace unusable pins (~€1-5).
- Connect all the wires to the new connector.
Okay, here's the translation:
"Ready."
Translated on 03-09-2026, 14:00.
Post10-01-2010, 23:47    Subject: Wiring Repair: ZV Pump Connector Fix Quote
The white part inside the connector should be a locking mechanism.
When you remove these, the contacts usually come out quite easily.
At least significantly better than in the Golf 2-3 era icon_smile.gif.
Translated on 03-09-2026, 14:01.
wbuchi82
Post13-01-2010, 23:06    Subject: Wiring Repair: ZV Pump Connector Fix Quote
hi!
Thanks again for the answers!
I've reviewed the entire situation again and discussed it with a colleague from a VW/Audi service center. He then gave me a cable stripper for the individual wires and a new cable connector with a pin (see attachment).
With this, I was able to easily and affordably replace the faulty cable. And the central locking pump is working perfectly again!
 File size:  311.55 KB
 Viewed:  6389 times
No new posts P261A, P261B - Pump for coolant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Headlight Washer Pump Leak - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts OBD2 Connector: Types, Uses & Benefits Diesel Engine Technology
No new posts Connectors: Find Suppliers & Buy Online Diesel Engine Technology
No new posts 2. K-line at the connector On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. ODB Connector: Buy Online Now! On-Board Diagnostics (OBD)
