Benni Blaumann
Joined: 11/19/2005 Posts: 302 Karma: +15 / -0 Location: Braunschweig
11-11-2009, 7:43 Subject: |
Passat 3BG 2.0 TDI - BGW EDC16 - yes, it's possible! Audi A5 B8 Cabrio 2.0 TFSI/CNCD 225PS
Passat Variant Highline 3BG EZ 2/04 2,0 TDI mit DPF 235tkm 2x DPF gespĂŒlt - RIP dank LKW
Translated on 12-07-2026, 18:33.
mullemaus Guest
12-11-2009, 1:08 Subject: |
Ihr dĂŒrft aber auch eins nicht vergessen, nicht bei allen EDC15 werden die KM mitgezĂ€hlt. Das ist selbst bei einem SteuergerĂ€t mit 2 verschiedenen SoftwarestĂ€nden schon so, das eine Version die KM mitzĂ€hlt, die anderen nicht.
EDC16 should generally be supported and integrated in most cases.
It doesn't work with the bus either; I've never had any success.
Some of the 102 models are compatible. Some of the 150 models exhibit the aforementioned phenomenon. The T5 engines themselves are EDC16 and should generally be compatible.
Mal blöd gefragt: gibt es auch Benziner die gehen?
It's filed with MED9/MED17. Whether, how, or when something will come from that â I don't know  .
Translated on 12-07-2026, 18:34.
matthiasTDI96 Profi-Schrauber
12-11-2009, 11:32 Subject: |
No, for our T5, it's not about the engine code (MKB): The Body Production Code (BPC) and Manufacturing Year (BJ) are 09/2007.
Translated on 12-07-2026, 18:35.
Benno Blaumann
Joined: 07/19/2002 Posts: 75 Karma: +2 / -0 Location: Heide
14-11-2009, 19:22 Subject: |
Okay, here's the translation:
"Regarding my Audi A6, manufactured in 2004, with engine code AWX..."
18-11-2009, 18:13 Subject: |
A glimmer of hope  : A 2008 Volkswagen Golf V with a BKD engine, it runs. MfG. Michael
Translated on 12-07-2026, 18:36.
Profile PM Garage |
CheBu Blaumann
23-11-2009, 14:31 Subject: |
Are the data actually "change-proof"?
Or can these be changed using the appropriate tools, just like the information displayed in the instrument cluster?
It would be nice if there were something reliable to rely on â besides the service booklet!
Stefan.
mullemaus Guest
23-11-2009, 14:43 Subject: |
Are the data actually 'change-safe'?
Stefan
No.
is easily editable. In most cases, even via the OBD interface  . Secure = hardly anything these days.
Translated on 12-07-2026, 18:37.
14-12-2009, 12:20 Subject: |
On Saturday, the issue I've been experiencing with different software versions, as mullemaus described, was confirmed. About a year ago, I had a 2006 Jetta with a BMM engine, and reading the mileage wasn't possible. On Saturday, I had it again, and I thought, "I'll just try it again," and sure enough, it worked  . In the meantime, the vehicle had been to VW for an inspection, where they likely performed a software update. There's no other explanation. MfG. Michael
Translated on 12-07-2026, 18:39.
Profile PM Garage |
05-02-2010, 11:56 Subject: |
2007 Passat with BMP engine, running.
2007 T5 with a BNZ engine, also works. MfG. Michael
Profile PM Garage |
mrport
Joined: 06/21/2009 Posts: 1 Karma: +0 / -0 Location: Oss Niederlande
17-02-2010, 12:56 Subject: |
My first small contribution, yay!
A4 size from 2000: works (and only a 1.2% deviation).
Best regards, Reinier.
Translated on 12-07-2026, 18:40.
