Marko wrote: |
I also moved the measurement short-circuit ring, but it's stiff (which is normal).
Still the same, though. |
Hi.
A stiff or sticking mechanism is not normal.
There should be only a very slight, easily overcome, spring force felt.
Quote: |
| P.S. What would happen if pin 2 & 3 were to touch or short to ground?? |
IMO, this is likely a false error message, and the engine would shut down for safety reasons.
Rainer K wrote: |
Are you sure that the lower stop of the RWG is not affected by shifting?
If not, then my setting instruction via MWB 13 is nonsense. |
In my opinion, this could only be the case if the minimum travel limit were defined by the free travel path of the main slide (zero position).
I suspect
, but that both mechanical stops are realized through a rotational angle limitation in the main spindle unit (MSW).
Because this would likely be better suited to absorb the "powerful" impacts during the signal box inspection than to transmit the force through the governor slide eccentric.
So far, I hadn't disassembled a pump before.
