Documentary: Octavia 1 / Golf IV fuel gauge malfunction (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Octavia_4x4
dieselschrauber likes this.
Post21-05-2010, 20:33    Subject: Documentary: Octavia 1 / Golf IV fuel gauge malfunction Quote
Vehicles: Golf IV / Octavia 1, 1.9 TDI with pump injector technology.
Problem description: The fuel gauge intermittently and non-reproducibly displays a normal reading initially, then suddenly jumps to a much higher value ("The car appears to be filling itself up while driving").
If the fuel level sensor fails, you will eventually run out of gas even with a "full" tank. In some cases, the fuel pump priming pump also doesn't activate when the ignition is turned on (the typical "gluckkkk" sound for 1-2 seconds).
Solution: Fold up the right-hand rear seat, remove the carpet, loosen and pry off the cover over the fuel filler opening (black) using 3 screws. Disconnect the connector from the fuel sensor/pump, apply some contact cleaner to the contacts, and reassemble.
Sure, here's the translation:
"Perhaps you could include some tips and tricks in the articles."
Translated on 12-07-2026, 21:23.
Ratings - Documentary: Octavia 1 / Golf IV fuel gauge malfunction
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia I 1999 - Front wipers only work when it's dry General Tips
No new posts Doku Caddy 9K9, MJ 98/99, Motor geht aus, Fehlercode 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tankanzeige mit VAG-COM auf 5L Reserve einstellen, geht das On-Board Diagnostics (OBD)
No new posts Tachoausfall bei 4er Golf TDI, Tankanzeige schwankt Transmission, Chassis, Body & Interior
No new posts Golf IV / Octavia 1 Climatronic: Geräuschbildung Transmission, Chassis, Body & Interior
No new posts Golf IV / Octavia: sporadisches Bremsenflattern Transmission, Chassis, Body & Interior
