Golf 3 AEX Idle Problems "Resolved"
Karma: +645 / -0   Thank you, like it!
Post29-05-2010, 9:40    Subject: Golf 3 AEX Idle Problems "Resolved" Quote
Hi.
I have a Volkswagen Golf 3 with a 1.4-liter, 60 horsepower AEX engine that I got from my old neighbor.
He has idling problems, and the error codes stored are:
"Idling speed control adaptation limit exceeded."
I removed the throttle body, cleaned it thoroughly, and used the 1551 tool to perform a basic throttle adjustment.
While it's running more smoothly than before, the underlying issue remains, and the idle speed with a warm engine is around 1200 RPM.
What do the experts recommend?
Rüdi.
Post29-05-2010, 10:13    Subject: Golf 3 AEX Idle Problems "Resolved" Quote
Okay, all done, everything's running smoothly again.
The temperature sensor for the MSG was giving a reading of only ~40°C when it was actually ~90°C. I installed a "new" one from stock, re-calibrated the throttle, cleared the error codes, and it was working fine.
Best regards, Rüdi.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4: Right Front Inner Fender Liner Transmission, Chassis, Body & Interior
No new posts TDI "Wiring Issues": Golf 3 Engine Control Problem? On-Board Diagnostics (OBD)
No new posts Golf Roof Antenna: Drill & Installation Dimensions Transmission, Chassis, Body & Interior
No new posts Accident Golf III Gti 20 years and "reference points"? Transmission, Chassis, Body & Interior
