Warm Start Issues After Diesel Tuning (1 Cylinder)
mozz
Post05-06-2003, 10:11    Subject: Warm Start Issues After Diesel Tuning (1 Cylinder) Quote
hello!
"On a 1994 Passat with a 1Z engine, we're experiencing annoying starting problems when the engine is warm. We replaced the injectors with 0.216 size injectors, and the software has been adjusted accordingly, but now it struggles to start when warm, which it never did before."
The car initially only had a chip installed; after its 225,000 km, we decided to give it new injectors, and why not install larger ones at the same time? icon_twisted.gif
To start with, before we made any changes, we checked the pump's injection start time, and it was below the lower tolerance limit.
After the adjustment, it idled much more smoothly. Then I replaced the injectors, and now it runs like a kitten. The only issue is that it takes about 3-5 seconds to start when it's cold.
Sure, no problem! Here's the translation:
"Thank you in advance!"
Sure, here's the translation:
"mozz" translates to "cheese" in English. It is a type of Italian cheese that is made from cow's milk.
"The fuel injection pump was replaced about 15,000 kilometers ago due to severe jolting/jerking, and that fixed the problem!"
Translated on 19-08-2026, 4:39.
Post05-06-2003, 10:19    Subject: Warm Start Issues After Diesel Tuning (1 Cylinder) Quote
It would have been better if you had adjusted the fuel injection start timing (in the basic setting mode) using the new injectors instead of the old ones.
Because it is likely that your new injectors have a higher opening pressure, which can be compensated for by adjusting the injection pump accordingly to advance the timing.
If I remember correctly, Ulf also wrote something similar in his report, namely that the other nozzles needed to be adjusted after they were installed.
Translated on 19-08-2026, 4:41.
mozz
Post05-06-2003, 10:33    Subject: Warm Start Issues After Diesel Tuning (1 Cylinder) Quote
Thank you, I thought someone who can read would have an advantage, and I actually found something using the search function as well! icon_wink.gif
I'll do it today and of course, I'll let you know how it goes!
"Hi, how are you?"
Translated on 19-08-2026, 4:43.
Post05-06-2003, 16:31    Subject: Warm Start Issues After Diesel Tuning (1 Cylinder) Quote
Rainer K. wrote:
If I remember correctly, Ulf also wrote something similar in his report, namely that after the...
The installation of the other nozzles had to be adjusted.
Hello.
That's absolutely correct; it's also mentioned in the specialized article on "Düsentausch" icon_cool.gif.
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ladedruck beim ARL nach Tuning Diesel Engine Technology
No new posts Timing Belt Condition After 3,000km (1Z, 04/94) Diesel Engine Technology
No new posts Ladedrucküberhöhung beim AFN nach Turbotausch Diesel Engine Technology
No new posts KI Issues BMW 35i B4: Starter/Battery Problems Transmission, Chassis, Body & Interior
