Document: Golf IV / Octavia 1 Water ingress at the doors (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Octavia_4x4
Post20-06-2010, 20:10    Subject: Document: Golf IV / Octavia 1 Water ingress at the doors Quote
Vehicles:
. Audi A3 8L
. Skoda Octavia 1U
. VW Golf IV / Bora
. SEAT Leon 1M
Error:
. Water ingress at the doors, where water often accumulates in the frame seal and then flows into the interior, especially after heavy rain.
. This can be provoked by spraying the gaps between the door and the fender with a high-pressure cleaner.
Cause:
. Door seal at the bottom of the door (lip seal) is worn, torn, or compressed. This is designed to repel water from the top, running down the side; however, after a certain age, it no longer does this, but instead directs the water like a gutter onto the inner door seal.
Short-term emergency repair:
. Expand the poetry. The lower sealing edge is shaped like a round pipe, so it is hollow inside; for a temporary solution, a suitable elastic material can be introduced into this round pipe; this "thickens" the sealing edge and restores the pressure against the A-pillar and the sills.
>> Material Type: I sprayed the seal with an elastic car body sealant. It is a temporary solution until the replacement seal is available.
Permanent Solution:
. Replace the gasket (approximately €15-€20), either by removing and replacing an old gasket or by having a new gasket ordered from a dealer.
Tips for Golf IV / Bora:
. Before replacing the seal, rule out the possibility that the cause is not a leaking door frame seal; the seal between the door and the frame plate, located below the door cladding, is also often leaking. Not available individually, Repair tip: Body sealant or suitable elastic sealant tape.
>> to identify when the dampness is not just on the seal, but is visibly running out from under the door frame.
>> In a Skoda Octavia 1U, there is no carrier installed, but a foam sheet, which is usually not the cause of the water ingress.
Ratings - Document: Golf IV / Octavia 1 Water ingress at the doors
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts Golf 3: Rear Door Corrosion - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 Door Noises: Documentary & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Water ingress door Passat 3B Transmission, Chassis, Body & Interior
No new posts Wassereinbruch - Womit Türen abdichten? Transmission, Chassis, Body & Interior
No new posts Water Leak Golf 4: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Golf V Door Panels: Are They Glued On? Transmission, Chassis, Body & Interior
