ASZ performance loss
captaindickei
Karma: +1 / -1   Thank you, like it!
Post22-06-2010, 20:54    Subject: ASZ performance loss Quote
I'm experiencing a noticeable loss of power in my Golf 4 TDI with the ASZ engine, 96 kW, and 180,000 km on the odometer.
I've uploaded a log file; hopefully you can make sense of it. Otherwise, I will definitely create the requested log files again (I don't really know much about this).
PS: The LMM is still from 01, so it's the first generation. Should we just replace it?
/files/401752418/Log_neu.csv.html" target="_blank" class="postlink" rel="nofollow">http://
(is a TrafficShare download, meaning: you don't have to wait).
Translated on 15-07-2026, 13:35.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post22-06-2010, 23:11    Subject: ASZ performance loss Quote
I don't know why, but the N75 models seem to be particularly popular at the ASZ (presumably a repair or service center).
Have you tested it yet?
For testing purposes, you can also try swapping it with the solenoid valve from the EGR system.
Translated on 15-07-2026, 13:37.
captaindickei
Post23-06-2010, 16:24    Subject: ASZ performance loss Quote
hi,
I once did a test where the VTG rod moves, and it actually slides back and forth smoothly. This would suggest that the N75 valve is working, right?
Hello.
Tagessuppe
Post23-06-2010, 16:52    Subject: ASZ performance loss Quote
If that's the case, then the N75 valve and the VTG (variable turbine geometry) should be functioning correctly.
LMM would then be the next candidate.
If this is only the first one, then I would suspect it even without a log file.
What amount of air is displayed as being drawn in at idle?
Translated on 15-07-2026, 13:38.
captaindickei
Post24-06-2010, 19:45    Subject: ASZ performance loss Quote
So, the LMM is still the first icon_wink.gif.
Can you identify anything related to KMM in the log?
Translated on 15-07-2026, 13:39.
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leistungsverlust AUY 85 KW Diesel Engine Technology
No new posts G3 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Power loss and ABS Diesel Engine Technology
No new posts Performance Loss Above 130 km/h (AJM) Diesel Engine Technology
