Codierung Türöffnung Caddy | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post11-06-2010, 12:23    Subject: Quote
Hello Micha,
They couldn't find any errors with my device, so I disconnected the battery for 30 seconds.
Jetzt öffnet der Türschlüssel alle Türen beim manuellen Aufsperren.
Nonsense. Here's what I've figured out now:
- If the vehicle was locked remotely, the key fob will only unlock the driver's door; all other doors will remain locked initially.
- If the vehicle was previously unlocked remotely and then locked with the key, the key will open all doors.
However, I don't quite understand the meaning. Why don't you just try it out for yourself?
Translated on 14-07-2026, 16:24.
Wiesel
Post29-06-2010, 14:15    Subject: Quote
Feedback...
The trick of "locking with a key" doesn't work on the Caddy.
With the key, only the driver's door opens, regardless of what happened before icon_confused.gif.
At the moment, it seems that the icon_smile.gif will likely cover the majority of the costs for a...
takes over the second radio key.
Micha
Translated on 14-07-2026, 16:25.
mullemaus
Post29-06-2010, 23:45    Subject: Quote
Feedback...
The trick of 'locking with a key' doesn't work on the Caddy.
Best regards, Micha.
Then the mechanical opening is disabled. icon_wink.gif You can also adjust it. icon_cool.gif Or the lock is defective. }
Translated on 14-07-2026, 16:26.
Wiesel
Post30-06-2010, 8:30    Subject: Quote
mullemaus wrote:
where *desperate_smiley*
Translated on 14-07-2026, 16:27.
mullemaus
Post30-06-2010, 11:25    Subject: Re: Coding door opening for Caddy Quote
Encoding: 008B04087F2D8405484A036000C0
Please test 008B04087F2D8705484A036000C0 and then check if the doors can be closed mechanically. Not all functions/control bytes have been identified yet, and some are not yet assigned with 100% accuracy. icon_wink.gif
Translated on 14-07-2026, 16:28.
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Heckklappe VW Caddy Mj.2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy: Onboard Network Coding Problem Solution Electrical Systems, Vehicle Electronics, Multimedia
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts Caddy Life On-Board Diagnostics (OBD)
No new posts Caddy interior lights On-Board Diagnostics (OBD)
