AGM Battery: Higher Voltage for BMW?
Benno
Post10-07-2010, 14:38    Subject: AGM Battery: Higher Voltage for BMW? Quote
Hello.
I intend to buy a used BMW AGM battery for my campervan.
Now the question arises whether these batteries are designed for a conventional charging voltage of a maximum of 14.4 V, or whether BMW vehicles that are equipped with these batteries as standard have a higher voltage of 14.7 V. I would appreciate any information you can provide.
Benno.
Translated on 09-09-2026, 18:03.
Post10-07-2010, 15:29    Subject: AGM Battery BMW: Higher Charging Voltage? Quote
Benno wrote:
Hello.
Now the question is whether these batteries are designed for a conventional charging voltage of a maximum of 14.4 V.
According to a manufacturer's flyer: Yes!
http://www.bannerbatterien.com/banner/files/FolderRunningBullD.pdf (Page 11)
I would still like you to request the correct datasheet for the exact battery you intend to use.
Translated on 09-09-2026, 18:04.
No new posts Battery Drain: Audi A2 8Z0 MJ 2002 Doc Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Care: Tips for Checking and Maintenance Technical Articles
No new posts Battery Life: Charging Voltage & Optimization Transmission, Chassis, Body & Interior
No new posts Higher Oil Temperature: Causes & Solutions Diesel Engine Technology
No new posts Charging voltage Renault Clio III gasoline 2009 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat TDI: Higher Idle Speed in Newer 130PS Models? Diesel Engine Technology
