Vibrating Cooler Fan: Troubleshooting & Fixes
Post13-07-2010, 12:08    Subject: Vibrating Cooler Fan: Troubleshooting & Fixes Quote
Hi.
"Since the air conditioning has been running more frequently lately and the fan is turning on, I've noticed the following issue with our MK4 Golf G5 1.9 TDI (BLS):"
- The fan blades are asymmetrical - obviously, to avoid resonances.
- The entire wheel itself appears to be undamaged.
- When the fan is running at high speed, it vibrates so much that the entire car hums.
- The dual fans in the Passat operate almost silently.
Do the simple ventilation fans have balancing weights, which may be missing?
Are they generally more sensitive, which explains why the quieter dual fans are used in the technically identical cooler package of the higher-end Passat?
I hate that tingling sensation of about 50 Hz in my hands; it makes me feel scared.
Translated on 24-08-2026, 7:50.
Post13-07-2010, 13:03    Subject: Cooler Fan Vibration: Troubleshooting & Fixes Quote
dieselmartin wrote:
Do the simple ventilation fans have balancing weights that may be missing?
Yes, those are normally metal clips attached there. They can sometimes come loose and fly off; I've experienced this before, although not specifically with a Golf V, but with other models like the Leon, etc.
EDIT: This is what it looks like, located on the right side of the wing (example image, not from a Golf V).
http://www.shop-autoersatzteile.de/artikel/bilder/shop/8a8088200c24e09d010c8be6c3d10756/img_7378.jpg
Translated on 24-08-2026, 7:52.
Post13-07-2010, 13:23    Subject: Vibrating Cooler Fan: Troubleshooting & Fixes Quote
Damn.
And once they're gone, you also don't know how to restore a previous state... ?
Translated on 24-08-2026, 7:53.
Post13-07-2010, 13:37    Subject: Vibrating Cooler Fan: Troubleshooting & Fixes Quote
dieselmartin wrote:
and once they are gone, you also no longer know how to restore a previous state...
You could check if you can still see the impression where it was. But even so, we still don't know how many "g"s there were.
Translated on 24-08-2026, 7:54.
Octavia_4x4
Post13-07-2010, 13:39    Subject: Vibrating Cooler Fan: Troubleshooting & Fixes Quote
"The problem I'm having is with the blower motor inside. Even at full speed, it vibrates so much that the gas pedal vibrates too."
Since I can't find the brackets anymore, I'm going to let the engine fail and then buy a used one instead... because who knows where those brackets ended up being blown into the ventilation system.
Post13-07-2010, 14:34    Subject: Vibrating Cooler Fan: Troubleshooting & Fixes Quote
The weights from the interior fan should be located inside the pollen filter.
Translated on 24-08-2026, 7:55.
Post13-07-2010, 14:54    Subject: Vibrating Cooler Fan: Troubleshooting & Fixes Quote
Octavia_4x4 wrote:
I'm having a problem with the blower motor inside...
even at full speed, the gas pedal vibrates...}
Have you checked it? If there's a leaf stuck in there, it can cause serious imbalances, which I've experienced multiple times with Golf IV and Fabia models. Remove the leaf, and the fan will run smoothly.
Translated on 24-08-2026, 7:56.
Octavia_4x4
Post13-07-2010, 14:58    Subject: Vibrating Cooler Fan: Troubleshooting & Fixes Quote
dieselmartin wrote:
The weights from the internal fan should be inside the pollen filter.
Not applicable to the Octavia/Golf IV: In those models, the cabin filter is located at the top of the blower housing, underneath the windshield wiper on the right side. Then comes the recirculation flap, and finally the blower motor.
TDI-GTI-4-Motion wrote:
Have you checked it yet? If there's a leaf inside, it can cause serious imbalances, which I've experienced multiple times with Golf IV and Fabia models. Remove the leaf, and the fan will run smoothly.
"Yes, it would have been nice. But nothing would get through anyway, because there's a filter in front of it... I'd like it to be like that, then it could be fixed quickly."
Translated on 24-08-2026, 7:57.
Post13-07-2010, 15:47    Subject: Vibrating Cooler Fan: Troubleshooting & Fixes Quote
not compatible with the Octavia / Golf IV
You mean the first generation Octavia.
The VW Polo (Mk5) actually has the same climate control system as the Golf 5.
Translated on 24-08-2026, 7:58.
Octavia_4x4
Post13-07-2010, 15:52    Subject: Vibrating Cooler Fan: Troubleshooting & Fixes Quote
Okay, I understand. Please provide the text you would like me to translate from German to English.
Okay, I thought it was clear from the context that we were talking about the Octavia in relation to the Golf IV, but I'm referring to the first generation Octavia (O1).
Translated on 24-08-2026, 7:59.
Post13-07-2010, 16:27    Subject: Vibrating Cooler Fan: Troubleshooting & Fixes Quote
Octavia_4x4 wrote:
However, no leaves would get through either, because there's a filter in front of it...
Yes, I thought so too, but the practice has repeatedly shown me otherwise. I have no idea how they manage, maybe they are cutting corners on filter changes icon_question.gif.
No new posts Document: MKB AKF, Vehicle vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B Headlight Vibration: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 BPW vibrates/jerks Diesel Engine Technology
No new posts Audi A8 3.3 TDI AKF Vibration Problem Diesel Engine Technology
No new posts Audi A6 (4B) vibrates from 140 km/h Transmission, Chassis, Body & Interior
No new posts Vibrating PSA CR DI (Suzuki) at 1500 RPM Diesel Engine Technology
