Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1511 Karma: +645 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
07-07-2010, 12:28 Subject: Passat TDI Speed Sensor: Problems & Solutions |
Hi there.
My friend bought a facelifted 1995 Passat 35i with a 1Z TDI engine.
It doesn't have a digital odometer like I'm used to; instead, it has a good old-fashioned mechanical odometer driven by a speedometer cable.
Now the question: Is this reading normal for this TDI engine, or does it indicate a problem somewhere between the potentially existing Hall sensor and the engine control unit (ECU)?
Unfortunately, I can't physically inspect the car myself, as it's located 400km away from me.
Thank you, Rüdi.
| Description: |
| File size: |
109.9 KB |
| Viewed: |
2728 times |
Translated on 08-09-2026, 8:18.
Profile PM Garage |
Held467 Blaumann
07-07-2010, 18:09 Subject: Passat TDI Speed Sensor: Problems & Solutions |
is not normal.
He has a sensor in the speedometer.
Translated on 08-09-2026, 8:19.
07-07-2010, 18:11 Subject: Passat TDI Speed Sensor: Problems & Solutions |
Held467 wrote: | is not normal.
He has a sensor in the speedometer | .
Thanks for the information, then he should develop that AI further.
Profile PM Garage |
moonwalker
23-07-2010, 12:05 Subject: Passat TDI Speed Sensor: Problems & Solutions |
Hello, the TDI engine in the 35I has a speed sensor located on the transmission. It has 3 pins. There's a plastic piece inside that sometimes breaks off, or the sensor itself might be defective.
Best regards, Florian.
Translated on 08-09-2026, 8:20.
Held467 Blaumann
23-07-2010, 14:20 Subject: Passat TDI Speed Sensor: Problems & Solutions |
moonwalker wrote: | Hello, the TDI engine in the 35I has a speed sensor on the transmission. It's a 3-pin connector. There's a plastic piece inside that sometimes breaks off. Or the sensor itself is defective.
Best regards, Florian |
If it doesn't have a digital counter, the sender in the speedometer is responsible for displaying the speed.
Translated on 08-09-2026, 8:21.
moonwalker
23-07-2010, 18:10 Subject: Passat TDI Speed Sensor: Problems & Solutions |
Does this version still exist?
