VP44: Welche elektrischen Fehler werden per Diagnose erkannt | Posts 16+
Go to page: Previous  1, 2
Ruffy
Karma: +2 / -1   Thank you, like it!
Post22-08-2010, 22:50    Subject: Quote
So, I looked at the instructions and I didn't expect it to be possible with just a simple IRFZ.
However, I just looked at the datasheets and would actually prefer to choose the IRFZ46N! This corresponds much better to the original component in terms of thermal properties.
Edit: I can imagine that the IRLS3034 shouldn't get so hot^^ So, they are probably being very cautious, but it is completely oversized. As I said, the IRFZ46N is slightly better than the original according to the datasheet. If you were to use an IRFZ48N, you would definitely outperform the original component. And the advantage of IRFZs is really the price... --> around 60 cents icon_biggrin.gif
Marcus
Deus Violentia
Post26-08-2010, 17:54    Subject: VP44 Tool Quote
No new posts Reducer flow not detected Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts AAT with VP37: Key Values to Display On-Board Diagnostics (OBD)
No new posts DPF Cleaning: Which Values Are Adjusted? Diesel Engine Technology
No new posts Ford Mondeo - Which diagnostic software is suitable? On-Board Diagnostics (OBD)
No new posts Delete Errors Individually: A Step-by-Step Guide On-Board Diagnostics (OBD)
