Loud Engine Noise at High RPM - Troubleshooting
trulala
Post13-06-2003, 14:34    Subject: Loud Engine Noise at High RPM - Troubleshooting Quote
Hello.
Since yesterday afternoon, after a long drive on the highway, I've been hearing a loud noise when I accelerate fully. It's most noticeable when I briefly accelerate hard at low RPMs. The noise sounds like something is either blowing or sucking very strongly.
The vehicle is a Volkswagen Golf 3 TDI with the AFN engine.
Vagcom is reporting the following error codes for the Climatronic system:
2 errors found:
00779 - Vertical acceleration sensor (G90)
30-10 - Intermittent connection or short circuit after the positive terminal.
00281 - Throttle valve actuator (V60)
35-00 - -
The first error code appeared today, after I replaced the outdoor temperature sensor. So, it probably has nothing to do with that.
Can someone help me, or do I need to take it to a repair shop?
Thank you.
Best regards.
Luc.
Translated on 05-09-2026, 7:10.
Post13-06-2003, 15:42    Subject: Loud Engine Noise: Help Needed! Quote
trulala wrote:
Since yesterday afternoon, after a long highway drive, I've been experiencing a loud noise when I accelerate fully. It's most noticeable when I briefly accelerate hard at low RPMs. The noise sounds like something is either blowing or sucking very strongly
Hi.
"This is typical for leaks in the intake manifold area between the turbocharger and the engine."
I would fix this quickly (and only drive very slowly until the repair is done) before the "useless" loader is ruined due to over-revving.
Vagcom reports the following error codes for the Climatronic:
2 errors found:
35-00 - -
The first error was only logged today, after I replaced the outdoor temperature sensor. So, it probably has nothing to do with it.
However, the TDI doesn't have either of those parts, so it's likely a software issue with VAGCOM.
Occasionally, the error codes get mixed up during the "unlocking" process...
Can someone help me, or do I need to go to the workshop?
The latter depends on one's manual skills...
Translated on 05-09-2026, 7:13.
trulala
Post13-06-2003, 18:11    Subject: Loud Engine Noise at High RPM - Troubleshooting Quote
hello
I found the problem. A pressure hose has burst, right before the suction nozzle; it's a piece about 20 cm long.
www.quirin.lu/test/1.jpg
www.quirin.lu/test/2.jpg
Thank you for the quick help.
Luc.
Translated on 05-09-2026, 7:15.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Driving Too Dumb? A Brave New World Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
