3BG Door Problems: Handle and Lock Cylinder
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
haithamina
Post24-09-2010, 20:28    Subject: 3BG Door Problems: Handle and Lock Cylinder Quote
Related to the topic:
After removing the porous sealing strip from the aggregate carrier or baking sheet on the passenger side and applying/kneading VW sealant, I can no longer fit the lock cylinder housing into the door handle.
I need to thread a cable through the door handle (similar to a bicycle brake cable with a cylindrical end), which is connected to a lock that is mounted on the generator support.
After that, the cylinder housing should be inserted from the outside and secured with a locking ring. The locking ring is rotated with a screw so that it slides under the protrusions of the cylinder housing and secures it in place. The screw is accessed from the direction of the lock and its mounting screws.
"Somehow, nothing is working. Even in the ideal scenario (the rope isn't attached to the door handle, the generator carrier is far away, and I'm looking into the door from the inside, trying to figure out how it should work)."
Does anyone else experience this problem, and can you offer any advice?
I'm feeling really down. There's been a marital argument, we have visitors coming tomorrow, it's raining and dark, and right now I can only see the option of throwing everything into boxes, securing the door, replacing the missing window with a plastic bag, and getting rid of everything as soon as possible...
haithamina
Türgriff.pdf
 File name:  Türgriff.pdf
 File size:  9.47 MB
 Downloaded:  1304 times
Translated on 10-07-2026, 21:41.
pax
Avatar-pax
2000 Volkswagen Passat
Post26-09-2010, 16:54    Subject: 3BG Door Problems: Handle and Lock Cylinder Quote
Door lock 3B, rear (?)
 File size:  153.49 KB
 Viewed:  10316 times
Translated on 10-07-2026, 21:43.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Remove Door Lock Cylinder Without Key Transmission, Chassis, Body & Interior
No new posts A4 B5 ABS Problems Transmission, Chassis, Body & Interior
No new posts 2.5 TDI AAT Problems: Common Issues & Fixes Diesel Engine Technology
No new posts ALE: Troubleshooting GRA Issues in MKB Diesel Engine Technology
