Tire Tracks on Concrete: How Tires Leave Marks
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Wiesel
Post08-10-2010, 23:50    Subject: Tire Tracks on Concrete: How Tires Leave Marks Quote
Our Polo started making a noise while simply maneuvering in the parking lot on the paved surface.
Tire tracks are clearly visible on the concrete in the courtyard.
He didn't do that before, and now it's happening less frequently.
The problem mainly affects the two front tires (with the left tire being more affected).
"Approximately" at the same time, a strange smell (a mixture of cheap...)
Plastic bag / hot plastic and green soap icon_confused.gif), which appeared mainly on the front, left side.
It seems to decrease and then gradually diminishes towards the engine.
Has anyone ever observed something like this before, or have any ideas about it?
Micha
Translated on 04-09-2026, 17:16.
Post09-10-2010, 8:57    Subject: Tire Tracks on Concrete: How Tires Leave Marks Quote
Completely misaligned tracking?
Here in our company parking lot, you can see a lot of tire marks, but (in my opinion, it's clear that) everything is so tight that drivers have to make full stops and maneuvers to get into their parking spaces.
Translated on 04-09-2026, 17:17.
Wiesel
Post09-10-2010, 10:35    Subject: Tire Tracks on Concrete: How Tires Leave Marks Quote
dieselmartin wrote:
Completely misaligned track?
I don't think so, because this behavior wasn't present before, and Martina hasn't been through any...
No potholes hit, and no contact with any curbs, and it's happening less and less.
I know about the tire marks that appear when maneuvering in tight spaces. Here are the tire marks.
However, it also occurred in wide curves.
My suspicion is that she drove over something that caused the tires to detach.
This might also explain the strange smell (which I don't usually associate with cars).
Micha
Translated on 04-09-2026, 17:18.
Post09-10-2010, 10:41    Subject: Tire Tracks on Concrete: How Tires Leave Marks Quote
That could be.
That very parking garage, where I see the signs of wear and tear here, is currently being repaired.
Now, we're going to add delicious epoxy resins, liter by liter.
I don't want to know what the tires say when you drive over them too early.
icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/img/parkdeck_epoxy7d5p.jpg" class="responsive" alt="http://www.
/img/parkdeck_epoxy7d5p.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
Translated on 04-09-2026, 17:19.
Karma: +438 / -0   Thank you, like it!
Post11-10-2010, 8:07    Subject: Tire Tracks on Concrete: How Tires Leave Marks Quote
Hello Micha,
Did Martina perhaps pass by while asphalt work was being done?
It's possible that the tire isn't actually touching the road, but rather that some adhesive layer (is that what it's called?) is stuck between the tread blocks. This is the layer that's sprayed between two layers of asphalt. However, to my nose, it smells more like a mixture of bitumen and plastic.
I'm not familiar with a "soap" smell coming from a vehicle being related to any problems.
Best regards, also to the pilot who caused the tire tracks.
Guste.
Translated on 04-09-2026, 17:20.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post11-10-2010, 10:50    Subject: Tire Tracks on Concrete: How Tires Leave Marks Quote
Hi, maybe it went through some kind of rubber-dissolving liquid beforehand, like a diesel spill at a gas station?
Another thought: The CV joint boot is broken, and grease is spraying out onto the rim and the tire.
reflexsilber met.
Translated on 04-09-2026, 17:21.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Turbocharger blades, strange traces Upload
No new posts Retreaded tires? Transmission, Chassis, Body & Interior
No new posts Reifen Rollwiderstand - uiuiui . . . Diesel Engine Technology
No new posts Uneven Tire Wear: Causes and Solutions Transmission, Chassis, Body & Interior
