Voltage Sensor 1 - Probe 1 too small
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
michiglaser
2007 Audi A4 Avant
Post30-10-2010, 23:23    Subject: Voltage Sensor 1 - Probe 1 too small Quote
Hello!
What does the error message mentioned in the title refer to?
Does this also refer to the oxygen sensor?
Thursday, October 28, 2010, 15:17:28:39738
VCDS Version: RKS 10.6.1
Address 01: Engine
Label file: RKS\059-907-401-ASB.lbl
Control unit part number: 8E0 910 401 P. Hardware: 8E0 907 401 AL.
Component and/or version: 3.0L V6 TDI, G000SG, 0050.
Encoding: 0011911
Operating number: WSC 06335 000 00000
VCID: 2C52877CF679
4 errors found:
005658 - Spark plug, cylinder 1 (Q10): Interruption.
P161A - 001 - Upper limit exceeded.
Environmental conditions:
Error status: 01110001
Error priority: 0
Error frequency: 1
Mileage: 89081 km
Time: 0
Speed: 924 RPM
Torque: 101.4 Nm
Speed: 0.0 km/h
Key press ratio: 1.0%
Voltage: 14.67 V
Key press ratio: 24.9%
Temperature: 9.0°C
000305 - Bank 1, Probe 1: Voltage too low.
P0131 - 001 - Upper limit exceeded - Intermittent.
Error status: 00100001
Error priority: 0
Error frequency: 9
Mileage: 89753 km
Time: 0
Speed: 1428 RPM.
Torque: 343.2 Nm
Speed: 33.6 km/h
Key press ratio: 100.6%
Air mass/flow rate: 622.8 mg/H
(no unit): 0.90
(no unit): 0.0
004481 - Linear lambda sensor/reference voltage: Open circuit.
P1181 - 000 - -
Error status: 01110000
Error priority: 0
Error frequency: 9
Mileage: 89753 km
Time: 0
Speed: 1911 RPM
Torque: 479.7 Nm
Speed: 42.6 km/h
Key press ratio: 34.9%
Air mass/Exposure: 881.3 mg/H
(no unit): 0.90
(no unit): 0.0
004484 - Linear lambda sensor/common ground wire: Open circuit.
P1184 - 000 - - - Sporadic.
Error status: 00110000
Error priority: 0
Error frequency: 1
Mileage: 90,371 km
Time: 0
Speed: 756 RPM
Torque: 46.8 Nm
Speed: 2.2 km/h
(no unit): 12.8
(no unit): 0.0
(no unit): 0.0
Readiness: 1 2 0 0 0
Otherwise, it seems a badger may have caused damage to the plane.
I was under the car and replaced a damaged hose (I suspect it's a pressure hose; it connects to the DPF). I also attribute those two lower errors to those animals.
Michael.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Post31-10-2010, 0:04    Subject: Voltage Sensor 1 - Probe 1 too small Quote
Does this also apply to the oxygen sensor?
Yes.
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code 15733 - NOx catalyst, bank 1 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0171 Fuel System Bank 1 Lean Mixture Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reduction system, bank 1 / SCR NOx catalyst, bank 1 Diesel Engine Technology
No new posts Lambda Sensor Error On-Board Diagnostics (OBD)
No new posts Spannung Frontscheinwerfer Transmission, Chassis, Body & Interior
No new posts Lambda-Sonde (G39)- Kurzschluß nach Plus On-Board Diagnostics (OBD)
