Golf VI speaker crossover - Where is it located?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +1102 / -0   Thank you, like it!
Post31-10-2010, 18:06    Subject: Golf VI speaker crossover - Where is it located? Quote
A question came up from my circle of friends:
Since both (!) front woofers in my car have been malfunctioning for quite some time (although the speakers in the back are present, they are not connected), but not always at the same time, I would like to investigate the issue.
I therefore suspect the crossover filters. To confirm this for sure, I would first need to know where they are located, and whether I, as a regular person, can access them without breaking any plastic parts (okay, to be honest, with that car, it probably wouldn't matter if I broke one more part, because a large portion of the plastic parts are already prone to falling off just by looking at them...
Turbinchen
Karma: +75 / -0   Thank you, like it!
2014 Audi A4 Avant
Post01-11-2010, 13:22    Subject: Golf VI speaker crossover - Where is it located? Quote
If it's the same with the VW as it is with the A3, then the crossover is no longer like a capacitor, directly connected to the speaker.
Post01-11-2010, 13:32    Subject: Golf VI speaker crossover - Where is it located? Quote
...which in this case likely only applies to the high-tone areas. According to that, does the subwoofer get the entire frequency range?
Where could the vulnerability lie that would cause the deep-sea vehicles to fail?
michiglaser
2007 Audi A4 Avant
Post02-11-2010, 10:17    Subject: Golf VI speaker crossover - Where is it located? Quote
Golf 6?
"Shouldn't it still be under warranty?"
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Post02-11-2010, 10:34    Subject: Golf VI speaker crossover - Where is it located? Quote
Turbinchen
2014 Audi A4 Avant
Post04-11-2010, 12:03    Subject: Golf VI speaker crossover - Where is it located? Quote
Hi, I haven't been able to access the forum for the past few days. You're right, the mid-bass speakers in the doors are receiving the full frequency range. However, there can be many potential sources of error, such as the cables in the door hinge. I'm also not ruling out the possibility that the radio itself is faulty; the quote suggests that an aftermarket radio might be installed. It might also be due to the wiring behind the radio; I've made some pretty awful discoveries back there with things like screw terminals and power taps.
The "Hochtöner" will probably continue playing, even in problem situations.
Post04-11-2010, 12:32    Subject: Golf VI speaker crossover - Where is it located? Quote
Yes, they are continuing to play.
R.M.
Karma: +14 / -0   Thank you, like it!
Post04-11-2010, 12:41    Subject: Golf VI speaker crossover - Where is it located? Quote
Then please check the woofers for continuity; the coil may be burned out. Unplug the radio before you start.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Speaker Installation Guide Transmission, Chassis, Body & Interior
No new posts Passat 35i: How to Replace Car Speakers Transmission, Chassis, Body & Interior
No new posts Radio installation T6, Rear speaker retrofit for van Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
