Schlag während der Fahrt - danach keine Leistung mehr | Posts 16+
Go to page: Previous  1, 2
Aliendrummer
Karma: +6 / -2   Thank you, like it!
Post25-11-2010, 23:38    Subject: Quote
Sorry, I'll do a new one tomorrow.
Translated on 16-08-2026, 9:11.
Post26-11-2010, 11:30    Subject: Quote
In the full-load cycle, ranging from 151 seconds to 165 seconds, the target boost pressure is not reached.
That's why he's running at the smoke line.
From 1018 seconds to 1053 seconds, the full load lasts long enough for the boost pressure to finally reach the target value after 9 seconds (!).
Post26-11-2010, 11:46    Subject: Quote
From 151 to 165 seconds, the speed also increased from 1533 over 1449 to 1596 RPM...at 100% load.icon_sad.gif
Translated on 16-08-2026, 9:12.
Aliendrummer
Post26-11-2010, 12:28    Subject: Quote
Can you draw any conclusions from this yet?
Post26-11-2010, 13:41    Subject: Quote
Aliendrummer wrote:
Can you already draw conclusions from this?
Well, it looks like you drove up the Eiger North Face in 5th gear icon_twisted.gif.
//EDIT: Your boost control is too slow.
Translated on 16-08-2026, 9:13.
Aliendrummer
Post26-11-2010, 14:38    Subject: Quote
//EDIT: Your boost pressure control is too slow.
No, no... You can quite accurately replicate the "Eiger North Face" experience in the Sauerland with just 55 kW. icon_smile.gif
Could this delayed speed be related to the patched hoses? After all, connectors were installed there, which reduce the cross-sectional area of the hose.
Translated on 16-08-2026, 9:14.
Post26-11-2010, 14:50    Subject: Quote
- 19559 4C67 P3103 engine for throttle valve V157 defective
Have you looked into that?
Translated on 16-08-2026, 9:15.
Post26-11-2010, 14:54    Subject: Quote
Now explain to me what you're planning to do, so I can understand it.
Are you trying to get the device working perfectly again, or are you just looking for a quick fix?
If the former is the case: Please ensure that all defective parts are properly repaired. This means they must be restored to a condition where their dimensions, fit, and material match those of an original part. Only then does a well-executed repair make sense...
Translated on 16-08-2026, 9:16.
Aliendrummer
Post28-11-2010, 17:59    Subject: Quote
Roger wrote:
- 19559 4C67 P3103 Engine for throttle body V157 defective
Did you ever look into that?
The aforementioned error no longer occurs.
Now explain to me as well, so that I can understand, what you are planning.
If the former is the case: Please fix all defective parts. This means fixing them so that they match an original part in terms of dimensions, fit, and material. Because only at this point does a properly executed process make sense...
matthiasTDI96 wrote:
Of course, I'd like to get the machine working again, but I personally don't have the ability to do any repairs myself. Therefore, I need to rely on a workshop.
Translated on 16-08-2026, 9:17.
Post29-11-2010, 8:58    Subject: Quote
Okay.
Then take it to a workshop (a different one) and have the cracked and porous hoses replaced with original parts (or comparable ones). Afterwards, the entire LD system should be checked for leaks. Then, run a full-throttle test in each gear from approximately 1000 RPM to 4500 RPM and we'll see how slowly the boost pressure builds up.
Translated on 16-08-2026, 9:19.
No new posts Golf5 Getriebe schaltet während d. Fahrt nicht in alle G... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2263 - Turbocharger/Compressor, System: No Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine No Power Below 3000 RPM, Then Normal! Diesel Engine Technology
No new posts 1Z Motor hat keine Leistung mehr... On-Board Diagnostics (OBD)
No new posts jetzt hat er gar keine Leistung mehr Diesel Engine Technology
No new posts TDI 2.5 T4 engine no longer provides performance. Diesel Engine Technology
