Diesel Viscosity: Blends with Crude Oil
Post23-06-2003, 9:46    Subject: Diesel Viscosity: Blends with Crude Oil Quote
The following links were mentioned to me some time ago in the Fatty-Fuels forum.
From the diagrams, everyone can draw their own conclusions about how much more stress a fuel injection pump experiences when using a thicker fuel.
http://mitglied.lycos.de/markusle/Bilder/Viskositaet.jpg
Mixing at a constant temperature, with a defined flow rate through a specific opening:
Translated on 29-10-2026, 18:20.
Gremlin
Post23-06-2003, 11:12    Subject: Diesel Viscosity: Blends with Crude Oil Quote
Let's just say:
I would definitely not recommend using P-oil with a VP37-EDC at temperatures below 70°C.
I don't think the hub and bearing will last very long.
By the way, adding gasoline to diesel is almost as prohibited as using heating oil itself.
CU Gremlin.
Translated on 29-10-2026, 18:21.
Post25-06-2003, 23:21    Subject: Diesel Viscosity: Blends with Crude Oil Quote
Not only are the impeller and bearing ring subjected to higher loads; ultimately, the increased pressure, acting as a torque peak, is supported by the pump drive wheel.
In plain terms, this means that the timing belt is subjected to greater stress due to higher torque peaks, and it may be advisable to replace it prophylactically a bit earlier (especially when operating primarily on vegetable oil).
Alex.
Translated on 29-10-2026, 18:22.
donalexo
Post25-06-2003, 23:23    Subject: Diesel Viscosity: Blends with Crude Oil Quote
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 29-10-2026, 18:23.
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Diesel 2.0 170 HP: Specs & Performance Diesel Engine Technology
No new posts LD Log A3 8P 2.0 CR Diesel Upload
No new posts Diesel Engine Oil Diesel Engine Technology
No new posts 2-Stroke Diesel Engines: The Sequel Diesel Engine Technology
