1.9 TDI ATD: Scheppern beim Anfahren | Posts 32+
Go to page: Previous  1, 2, 3
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post30-11-2010, 23:11    Subject: Quote
RedR32 wrote:
I have already replaced the noisy pulleys of the timing belt tensioner, so I replaced the entire part.
How about checking the engine, maybe just a quick push with your hand?
When you remove the oil pan, check the oil pump's suction pipe for any obstructions. To do this, simply unscrew it from the oil pump. This will give you peace of mind.
reflexsilber met.
Translated on 06-08-2026, 22:36.
Octavia_4x4
Post01-12-2010, 22:41    Subject: Quote
Okay,
Replace the belt tensioner tomorrow, and then I'll see exactly what was wrong icon_smile.gif.
Translated on 06-08-2026, 22:37.
Octavia_4x4
dieselschrauber likes this.
Post02-12-2010, 17:06    Subject: Quote
Okay,
After the rattling noise we heard earlier today, and now with the intermittent flickering of the battery warning light, it seems the part was definitely due for replacement.
Result:
- Lima is working perfectly again.
- All rattling noises at idle, under load, and during startup >> gone.
- Engine operation: much smoother than before.
"Something else I've noticed is that the car needs less fuel... I often drive this route and have always used between 6.5 and 7.0 liters per 100 km – today it used 5.5, with the same driving style. It also seems to accelerate better, but I think that might be my imagination."
Anyway, the problem with the €25 tensioner (manufacturer: INA - same part numbers as the VW tensioner already installed and same manufacturer name) and the €0.25 labor cost is solved. Fortunately, it was possible to replace it on the Octavia without having to remove any hoses or cables.
"Something was added to it, and the part that was installed has been replaced with something else – apparently there were improvements. If you tap the defective part, you can hear a metallic rattling sound. And the bearing has about 2mm of play."
Translated on 06-08-2026, 22:38.
Deus Violentia
Post02-12-2010, 19:56    Subject: Quote
BKD GRF
AHF EBF
Translated on 06-08-2026, 22:40.
Octavia_4x4
Post02-12-2010, 21:56    Subject: Quote
Yes, I'm really amazed by the quietness of the ATD icon_biggrin.gif. I can finally drive at 60 in 6th gear again without getting a noisy racket from the front. It's truly amazing how much noise such a simple tensioner can make...
Translated on 06-08-2026, 22:41.
No new posts A4 1.9 TDI: Engine Jerks Like Clutch Slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Starting Problems: Lack of Power On-Board Diagnostics (OBD)
No new posts "4B AFB preheating indicator flashes during startup." Diesel Engine Technology
No new posts Clutch Control: Starting & Idle (DSG) Transmission, Chassis, Body & Interior
No new posts Audi 80 B4: Jerking When Starting - Fix! Transmission, Chassis, Body & Interior
