Quote: |
| Could the old switch possibly fit in my Golf? |
Yes, the one without the rocker switch, the one with the "Set" button, will fit.
Unfortunately, I'm not sure if the rocker switch would work in your case. If you bought a retrofit kit, there should definitely be an instruction manual included. However, in my manual, the connector was incorrectly labeled, showing where the contacts are supposed to be inserted.
