Update USB Drivers: How to & Troubleshooting
peterhilgert
Post02-01-2011, 21:57    Subject: Update USB Drivers: How to & Troubleshooting Quote
During the last update to VSDS-RKS-GER10.06, it indicated that my USB driver is outdated and suggested installing version 03.01.19/02.06.01.
Where can I find him?
Thank you in advance for your help.
Peter Hilgert.
Translated on 26-07-2026, 9:41.
Post03-01-2011, 8:10    Subject: Update USB Drivers: How to & Troubleshooting Quote
The "current" driver is automatically installed during the installation process, and usually there's nothing else you need to do.
Apparently, there was some confusion regarding the versioning of the drivers.
If Windows or VCDS is persistently causing problems due to incorrect driver versions, simply uninstall the old drivers and reinstall the package.
Translated on 26-07-2026, 9:42.
No new posts USB Drivers for HEX-COM+CAN (W98) Broken:-( On-Board Diagnostics (OBD)
No new posts VCP drivers for HEX-USB+CAN are missing!/? On-Board Diagnostics (OBD)
No new posts HEX-USB+CAN, KEY-USB, HEX-USB, new Windows and drivers On-Board Diagnostics (OBD)
No new posts USB CAN Interface: Driver Installation Issues? On-Board Diagnostics (OBD)
