T4 111kW jerks/stalls
Gerrit Jan
Post01-07-2003, 1:39    Subject: T4 111kW jerks/stalls Quote
Hello diesel mechanics,
Unfortunately, we're having a problem with our T4, engine AHY. Occasionally, the car jerks or completely stops running. This happens when we try to accelerate and give it full throttle at around 2000 rpm. It's much worse when we're towing a caravan, and it can also happen during normal driving. The first time it happened, the engine had absolutely no torque but continued to run at around 1300 rpm. It didn't respond to the accelerator at all! We simply turned off the ignition and restarted it, and it started working again. The last time, I quickly turned the ignition off and on while driving. Then it was okay again, but it triggered error code 18047. Otherwise, there are no other errors, and apparently, relay 109 is not the problem either.
It would be very kind if someone could help us with this!
Gremlin
Post01-07-2003, 9:14    Subject: Re: T4 111kW - Jerking/Stalling Quote
The first time it happened, the engine had absolutely no torque but continued to run at approximately 1300 rpm. No response to the accelerator!
Okay, that's already a clue as to the cause...
Then it was working again, but it caused error 18047. Otherwise, there are no other errors, and apparently, relay 109 is not the problem either.
and THAT gives you the certainty...
Error code: 18047
Accelerator pedal position sensor (G79) - implausible signal.
Possible causes:
G79 is defective.
Possible consequences:
increased idle speed
The search function would have told you that too if you had searched for '18047'...
-> Check the accelerator pedal and its wiring!
CU Gremlin.
Gerrit Jan
Post01-07-2003, 16:22    Subject: T4 111kW jerks/stalls Quote
icon_redface.gif Thank you, Gremlin, you are of course right. I'm starting work right away this evening.
No new posts A4 8D Document: Timer Stuck - Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 111kW AHY, auxiliary heater defective Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 8E2 Wiper Problems: Fix Sticking Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVB: Intermittent Freezing Issues Diesel Engine Technology
No new posts ACV Stuck: "Scheppern" Explained - The Logic Behind It Upload
No new posts ALH rückelt im Leerlauf Diesel Engine Technology
No new posts VW T4 Steering Shaft 111kW AHY EEZ Transmission, Chassis, Body & Interior
