PD Leitungssatz wechseln - Problem bleibt bestehen (GELÖST) | Posts 16+
Go to page: Previous  1, 2
hame22
Post08-01-2011, 23:05    Subject: Quote
How long does it take for the engine to start misfiring or shutting down?
Is the time until the engine fails always the same?
Can the decay be prevented if you tamper with the gas?
Translated on 04-08-2026, 20:45.
Post09-01-2011, 12:55    Subject: Quote
Another idea: Perhaps the problem isn't with the motor or the control unit after all?
"On my A3 8L, I once had a faulty fuse box near the battery. The resulting electrical problems in the vehicle's wiring system led to approximately 30 horsepower less than usual and an emergency mode while driving, even though the power supply to the engine control unit (ECU) was not affected by the relevant fuse circuit!"
Translated on 04-08-2026, 20:46.
mullemaus
Post09-01-2011, 18:35    Subject: Quote
However, this only applies to the idle speed.
Um, no icon_lol.gif icon_wink.gif.
Translated on 04-08-2026, 20:47.
vwSchrauber
Post12-01-2011, 13:45    Subject: Quote
How long does it take for the misfires to occur or for the engine to stall?
Is the time period until the engine dies always identical?
"No, when I received the vehicle, it was supposedly not running at all. After I bled the fuel system (the previous owner had even bypassed the diesel filter!), it started immediately, and ran for about 20 minutes with intermittent misfires. Then, it only started sporadically..."
Can the decay be prevented if one manipulates the gas?
Negative - it has absolutely no influence.
On my A3 8L, I once had a defective fuse box on the battery, and the resulting electrical faults in the vehicle's wiring system led to approximately 30 horsepower of reduced maximum power and an emergency mode while driving, even though the power supply to the engine control unit (ECU) was not affected by the relevant fuse circuit!
That was also something I considered. However, the length of the component would place it just below the WSS on the left side, and the engine control unit (ECU) is located there as well. The crimp connectors that are in there are all okay, there are no signs of water damage, and the ground connection is solid icon_sad.gif.
vwSchrauber wrote the following:
Aha... the 2.0 16V TDI engine in the Touran, which had those problems, always sputtered during the warm-up phase at idle - sometimes to the point of stalling. A correction to a few maps, or characteristic curves, provided relief. When you look at it, you might think that the engineers intentionally programmed an oscillator there icon_lol.gif.
Translated on 04-08-2026, 20:49.
vwSchrauber
Post13-01-2011, 16:54    Subject: Quote
Okay, now the problem is solved icon_smile.gif.
Engine control unit replaced, now it's running again.
Inside was a 016 FE, and the exchange control unit has the identifier 016 SX.
The software version of device 016FE was 7002, while the software version of device 016SX is 9820.
Translated on 04-08-2026, 20:52.
Post13-01-2011, 18:32    Subject: PD Line Replacement: Issue Persists Quote
vwSchrauber wrote:
After some modifications, I am now able to state that a longitudinal installation of a PD requires a new wiring harness for the PDEs.
Vehicle: 8E, manufactured in 2005.
Engine: BKE
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Engine control unit replaced, now it's working again.
The software version of device 016FE was 7002, while the 016SX has 9820.
Hmm... then it seems that the old MSG has recently developed a hardware defect?
Because a software bug likely would have been driving the driver to despair for at least five years.
Translated on 04-08-2026, 20:54.
vwSchrauber
Post14-01-2011, 10:15    Subject: Quote
"@ulf: Not necessarily. The 2.0 16V TDI that I fixed the idle problems on back then only started exhibiting those issues due to wear and tear."
It is certain that this hardware error has already driven a VAG authorized workshop to despair (they replaced all sorts of things, even bypassed the fuel filter (!), etc.).
Translated on 04-08-2026, 20:55.
Post14-01-2011, 11:28    Subject: Quote
vwSchrauber wrote:
@ulf: not necessarily. The 2.0 16V TDI that I fixed the idle problems on back then only started exhibiting idling issues due to wear and tear.
It is certain that the hardware error has already driven a VAG authorized workshop to despair (they replaced everything possible, bypassed the fuel filter (!), etc...)
So, rather a software issue that is incompatible with wear and tear, which allows the hardware to function properly within narrow component tolerances?
That's exactly how my stuttering, starting BUK seems to me icon_rolleyes.gif.
Translated on 04-08-2026, 20:57.
No new posts A4 8D Document: Timer Stuck - Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo Tachometer Problem: 6X1 MJ 2002 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Clutch pedal remains at the bottom Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Sealing Kit for PDE Fuel Injector Lines Diesel Engine Technology
No new posts AVB: Intermittent Freezing Issues Diesel Engine Technology
No new posts Golf 5 clutch pedal stays down Transmission, Chassis, Body & Interior
No new posts T4 111kW jerks/stalls Diesel Engine Technology
