P1593 Error Code: Causes and Solutions
henneoderei
Post14-01-2011, 21:02    Subject: P1593 Error Code: Causes and Solutions Quote
I have a gasoline-powered car here, hopefully I'll still get an answer.
Here's the translation:
"Volkswagen Passat 3B, manufactured in 2000, with 170,000 km mileage, 1.8L engine, 125 HP, ADR compliant."
Jerks when accelerating. Fuel consumption: 10 liters.
Error code 18001, P1593: Altitude adaptation signal out of range.
I also had error code 16487 P 0103, which indicates a "Mass Air Flow Sensor Signal Too High". However, it cleared itself and hasn't reappeared.
Can someone tell me where the altitude signal comes from? Which sensor measures it?
Which technical data sheets (TDS) can I read?
Thank you for your replies.
Translated on 12-10-2026, 5:09.
Ross-Tech-Support
Post17-01-2011, 11:23    Subject: P1593 Error Code: Causes and Solutions Quote
Please post an auto-scan report, as this provides specific vehicle data and avoids having to make assumptions or give general answers.
http://wiki.ross-tech.com/wiki/index.php/18001/P1593/005523
http://wiki.ross-tech.com/wiki/index.php/16487/P0103/000259
Translated on 12-10-2026, 5:10.
Post17-01-2011, 11:33    Subject: P1593 Error Code: Causes and Solutions Quote
Please also enter your VCDS license information in your profile!
henneoderei
Post17-01-2011, 18:54    Subject: P1593 Error Code: Causes and Solutions Quote
Hello.
Unfortunately, I don't have a VCD or VAGCOM. I only have access to a VW tester occasionally.
Translated on 12-10-2026, 5:11.
Ross-Tech-Support
Post17-01-2011, 19:55    Subject: P1593 Error Code: Causes and Solutions Quote
You can also easily create and insert a diagnostic report here. icon_wink.gif
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G28 Error: Find the Mistake! Diesel Engine Technology
No new posts ABS error On-Board Diagnostics (OBD)
No new posts WFS Errors: Troubleshooting and Solutions Diesel Engine Technology
No new posts AGR errors On-Board Diagnostics (OBD)
