206 eco zu Golf 5 BLS | Posts 16+
Go to page: Previous  1, 2
Karma: +1099 / -0   Thank you, like it!
Post02-03-2011, 11:57    Subject: Quote
Here's a summary: With two legs of approximately 93 km each, each leg includes about ~15 km of country roads – enough for warming up and cooling down the engine and turbine. icon_wink.gif The rest is highway, and this is limited to 120 km/h for 2/3 of the distance. I would only use a start/stop automatic system for leisurely driving. For the 206, it's a relief that it has a relatively flat silhouette with a gently sloping windshield, a comparatively low front, and a reasonably acceptable rear design. The hatchback body style was already aerodynamically optimized in the design, and in the "eco" version, features like a full underbody panel, lowered suspension, and a longer transmission were added. [img] These flat front designs are a thing of the past, as are aerodynamic subcompact cars. The Golf seems much taller and bulkier than the Polo, and even its front end is not nearly as flat. The rear end of the Golf appears steeper, while the Polo seems almost boxy to me.
Side view: [/img]/download.php?id=5360
Mampf
Karma: +8 / -1   Thank you, like it!
Post02-03-2011, 22:13    Subject: Re: 206 eco vs. Golf 5 BLS Quote
Hutfahrer wrote:
Just a bit off-topic: At what point, approximately, does the BLS engine deliver its power at ~2500 RPM, and what would the power output be on a highway drive with a very light foot at that RPM/speed in 6th gear? Are you expecting a surge in consumption?
I also have a similar one with a 6-speed transmission, which I've owned since April 2007 (first registered in May 2006), and I've driven almost 80,000 km since then. The fuel consumption has been between 4.2 (summer, 90% highway, speedometer 95-100 km/h, the rest city driving with little traffic) and 5.7 (winter, 70% highway where allowed, speedometer 140 km/h, the rest city driving) liters per 100 km. "Typically, an Autobahn (highway) covers a distance of 220 km, including a 40 km stretch of tunnel (with speed limits of 100 km/h and 80 km/h respectively), a 20 km section with a speed restriction (100 km/h), and a total elevation difference of approximately 600 meters between the lowest and highest points."
Overall, the fuel consumption is approximately 4.85 liters per 100 kilometers. I find it noteworthy that the fuel consumption on long trips at temperatures just below 0°C is about 10% higher than it is at temperatures between 10-15°C – in both cases with a dry road surface and winter tires. As far as I recall, this difference wasn't as pronounced with the AFN model I had before.
The oil change intervals always reached the full 30,000 km (according to the display). Once, the two-year limit was reached first, and another time it was the $57a inspection (Austrian TÜV), where I "wasted" about 4500 km to avoid having to go to the dealership so close together (2 months). The third time, I almost reached the 30,000 km mark with 29,100 km. There was no need to refill the fluid between the intervals, but the last time, the level had reached the MIN mark.
As dieselmartin wrote, the responsiveness at low speeds is very good (much better than the 90kW TSI that we have in our family), and just above the speedometer reading of 200 km/h, it's also possible to achieve speeds on flat sections of the German autobahn (which is probably approximately equivalent to the registered 187 km/h).
Hutfahrer wrote:
In short: I want to drive at a speed of 110 to 120 km/h with my current fuel consumption rates.
Looking at your fuel consumption of 3.9-4.3 liters per 100 kilometers and considering the distance...
Hutfahrer wrote:
With two legs of 93 km each, each leg includes approximately 15 km of country road - enough for warming up and cooling down the engine and turbine. icon_wink.gif The rest is highway, and this is limited to 120 km/h for 2/3 of the distance.
... I have to say, I don't think that's enough. I *estimate* you'll need to add about 0.5 liters, maybe even more. I'm not sure what a Bluemotion would bring to this area, as I lack the experience to say.
Munch.
Post03-03-2011, 7:43    Subject: Quote
Best regards to Linz or Graz, and thank you very much for your valuable insights! When driving my small HDI car on the highway, I've noticed a tendency that it performs noticeably better when the temperature is below +5 degrees Celsius. With the same fuel consumption displayed by the car's computer, I can either drive a little faster or save 0.3 to 0.5 liters of fuel while maintaining the same speed.
Click on the Spritmonitor! The trips since the last refueling are exactly like that! No significant wind, consistently the same road conditions, and daytime temperatures of only 6 to 8 degrees Celsius, with morning frosts ranging between -8 and -5 degrees Celsius.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 3 Instrument Cluster in Golf 2 Dashboard Transmission, Chassis, Body & Interior
