LMM Curve: Troubleshooting Turbocharger Issues on VW T4 AHY
audiwinni
Post07-04-2011, 16:23    Subject: LMM Curve: Troubleshooting Turbocharger Issues on VW T4 AHY Quote
Hi everyone.
I have a question: I had a dynamometer test performed on my T4 AHY engine with the mass airflow sensor (MAF). See the image below.
Why are the target and actual values different when idling, even though the mass airflow sensor (MAF) is brand new?
I'm having a problem where my T4 is going into limp mode.
Error 17964: Turbocharger boost pressure regulation - Lower limit exceeded.
All hoses have been inspected; VTG certification is also available.
Before replacing the mass airflow sensor (MAF), the boost pressure curve looked like this (middle image).
After the exchange, see the image above.
 File size:  100.32 KB
 Viewed:  1704 times
 File size:  89.67 KB
 Viewed:  1498 times
 File size:  103.26 KB
 Viewed:  1528 times
Translated on 26-07-2026, 5:22.
Post07-04-2011, 18:57    Subject: LMM Curve: Troubleshooting Turbocharger Issues on VW T4 AHY Quote
Please enter your VCDS license information in your profile first.
Translated on 26-07-2026, 5:24.
No new posts AGR Target vs. Actual: Differences Explained Diesel Engine Technology
No new posts Boost Curve for AFB (Troubleshooting) Diesel Engine Technology
No new posts ESP Connectors: 8-Pin vs. 10-Pin Diesel Engine Technology
No new posts Passat 3C: Grinding Noise When Turning & Accelerating Transmission, Chassis, Body & Interior
