Golf 4 1.9 TDI Downpipe - ASZ Engine
vmann
Karma: +0 / -1   Thank you, like it!
Post08-04-2011, 13:27    Subject: Golf 4 1.9 TDI Downpipe - ASZ Engine Quote
I want to have a new exhaust system made for my Golf, from the catalytic converter onwards, using stainless steel and with a 2.5" pipe diameter. I have a question about the design of the downpipe. Would it be more advantageous to increase the diameter directly after the turbo, before the bend, or only after the bend and before the flexible section? With Milltek's downpipe, the diameter increases only after the flexible section.
MB Vito 2,2 CDI
VW Golf IV 1,9 TDI Variant
Translated on 21-08-2026, 0:50.
vmann
Post09-04-2011, 13:08    Subject: Golf 4 1.9 TDI Downpipe - ASZ Engine Quote
The solution was determined by the design constraints. The extension must follow the curve because otherwise, the flange cannot be attached.
MB Vito 2,2 CDI
Translated on 21-08-2026, 0:51.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Downpipe for turbo silencing on AJM engines Diesel Engine Technology
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
