Audi A3 2.5 TDI Engine Noise - 2003
jacomo
Post13-04-2011, 11:30    Subject: Audi A3 2.5 TDI Engine Noise - 2003 Quote
Also mein Problemkind ist eine Audi A4 8E B6 2,5 TDI mit 217000 km. Engine identification code: BAU.
The annoying habit he has that drives me crazy is as follows:
When driving at low RPMs, a noticeable grinding/whistling noise can be heard in the 1500 to 2500 RPM range, specifically when the turbocharger kicks in and builds maximum boost pressure. The noise is most noticeable when driving uphill, but it can also be heard when driving downhill using engine braking within the aforementioned RPM range. The turbocharger was replaced by the previous owner approximately 30,000 km ago. I have visited three VW/Audi workshops, and they all stated that the noise is normal. However, the noise was definitely not present when I purchased the car. As far as I understand, blowing air back into the air filter when downshifting is normal due to the presence of a VTG turbocharger.
Here's what I've already done:
Gewechselt habe ich das Ladedruckregelventil, einen Ladeluftkühler, Abgasrückführventil, Das Ventil welches die Druckdose des Abgasrückführventil steuert. Habe mir einen Stopfen mit einem Ventil gebastelt und die Ladeluftstrecke abgedrückt und seit dem ich alles gewechselt habe ist diese auch dicht. Die Unterdruckleitungen zum Turbo und überall anders hin habe ich ebenfalls kontrolliert – sieht gut aus -. Schlauch zwischen Luftmengenmesser und Turbo habe ich auch schon gewechselt da ein Riss unterhalb der Schelle zu finden war. Ladedrucksensor habe ich auch ausgewechselt. AGR is also new.
Error memory is empty.
Power loss... well... at first, it seemed like the car had better low-end performance.
I once logged the boost pressure and mass airflow sensor readings, but I can't make sense of the data.
Please help, I'm open to ideas, tips, and anything else you can offer. I'm grateful for any assistance.
lade3.CSV
 File name:  lade3.CSV
 File size:  3.18 KB
 Downloaded:  688 times
MAF.CSV
 File name:  MAF.CSV
 File size:  1.09 KB
 Downloaded:  589 times
Audi A4 B6 8E 2,5 TDI BAU Avant Quattro
Translated on 08-09-2026, 6:00.
Deus Violentia
Post13-04-2011, 11:47    Subject: Audi A3 2.5 TDI Engine Noise - 2003 Quote
Take a close look at the flexible pipes of the EGR system and the catalytic converter.
BKD GRF
AHF EBF
Translated on 08-09-2026, 6:01.
jacomo
Post13-04-2011, 12:22    Subject: Audi A3 2.5 TDI Engine Noise - 2003 Quote
Hello, thank you for your reply.
I've already replaced the AGR valve (it was leaking). I also checked the intercooler piping for leaks, but I didn't find anything. I could replace the crankcase ventilation (PCV) valve just in case. However, my research indicates that this engine uses a cyclone separator in the PCV system, which is not really prone to failure. When I remove the dipstick or open the oil filler cap with the engine running, I don't hear any hissing or feel any vacuum. Could the PCV valve still be faulty and causing these noises?
If anything in my assumptions is incorrect, please let me know. I'm just a hobbyist mechanic icon_smile.gif.
Sure, here's the translation:
"lg" is a German abbreviation that stands for "liebe Grüße," which means "best regards" or "warm greetings." It's commonly used in emails, letters, and other forms of communication to express affection or goodwill.
Translated on 08-09-2026, 6:02.
jacomo
Post14-04-2011, 7:39    Subject: Create Chart from Data Log Quote
I once created a diagram from the data log of the air mass sensor.
mafdiag.pdf
 File name:  mafdiag.pdf
 File size:  30.63 KB
 Downloaded:  528 times
Translated on 08-09-2026, 6:04.
jacomo
Post14-04-2011, 7:43    Subject: Create Chart from Data Log Quote
I have also created a diagram based on the boost pressure log.
Lade3 Neu.pdf
 File name:  Lade3 Neu.pdf
 File size:  22.3 KB
 Downloaded:  595 times
Post14-04-2011, 10:31    Subject: Audi A3 2.5 TDI Engine Noise - 2003 Quote
First, please enter your VCDS license information in your profile and send me a private message.
No new posts Document A2 8Z0 MJ 2003, noises from the front of the car Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0 MJ 2003, Hands-free device malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2003, broken rear spoiler Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fabia Speedometer 2003 ASY Electrical Systems, Vehicle Electronics, Multimedia
No new posts Driver's side fender liner, 3BG model, year 2003 Upload
No new posts Looking for Audi A4, year 2003, with VAG COM / Channel Ov... On-Board Diagnostics (OBD)
No new posts Power steering failure Audi A3, year 2003 Transmission, Chassis, Body & Interior
