3BPassatV6
Registered VCDS User
04-05-2011, 3:42 Subject: Airbag Control Unit: Coding Only? |
Since my airbag control unit is likely faulty, I would like to replace it with a new one that has the exact same part number: 6Q0909605B.
Is there anything else I need to consider when switching, besides simply transferring the old encoding to the new one?
There's a sticker on the airbag control unit that makes me a little more cautious.
"Warning: Airbag!"
This device contains vehicle-specific data for its operation.
"Do not install in other vehicles."
Does this mean that the software can be different even with the same part number, or is this just a general warning?
So, what else might need to be adjusted?
Thank you and best regards.
Translated on 25-08-2026, 21:47.
Ross-Tech-Support Profi-Schrauber
04-05-2011, 9:46 Subject: Airbag Control Unit: Coding Only? |
Do you have the necessary qualifications and permits to work on airbags? If not, you shouldn't be working on these systems. Also, the part number you provided is incomplete, and without a vehicle scan or VIN, no one will be able to provide you with the correct airbag coding.
Translated on 25-08-2026, 21:49.
3BPassatV6
04-05-2011, 11:33 Subject: Airbag Control Unit: Coding Only? |
@ Sebastian @Ross-Tech.com
Regarding the control unit:
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 605 B
Part: 05 AIRBAG VW5 0003
Encoding: 12341
Operating number: WSC 05311
VCID: 36692C9238D7
I don't plan on messing with the airbag system itself. And if even the workshop foreman says, "Just disconnect the airbag control unit â nothing can happen. The only thing that will happen is the airbag warning light will illuminate on the instrument cluster," then I thought I could also replace the control unit if it just needs to be reprogrammed.
However, if more than just a simple recoding is required, then I would refrain from doing it.
Translated on 25-08-2026, 21:50.
04-05-2011, 11:51 Subject: Airbag Control Unit: Coding Only? |
However, the complete vehicle scan and the Vehicle Identification Number (VIN) are still missing, but ultimately that doesn't matter. Furthermore, the coding of a control unit is also counted under "Work on airbag systems," because the coding process activates the control unit, and once it's activated, the airbag system can be triggered even by clearing the error memory.
Translated on 25-08-2026, 21:52.
3BPassatV6
05-05-2011, 0:45 Subject: Airbag Control Unit: Coding Only? |
Here's the complete scan:
VCDS Version: DRV 10.6.4
Data as of: 20110418.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Address 01: Engine Control Unit
Label file: DRV\059-907-401-AKE.lbl
Part number: 3B0 907 401 H
Part: 2.5l/4VTEDC G000AG D65
Encoding: 03004
VCID: 2241E0C2845F
"One error found:"
01117 - Load signal for generator terminal DF.
27-00 - implausible signal.
Readiness: Not Available.
Address 02: Transmission Label file: DRV\01V-927-156.lbl
Part number: 3B0 927 156 N
Part number: AG5 01V 2.5l TDI, Roadworthy date: 9503.
Encoding: 00010
Operating number: WSC 00000
VCID: 31631F8ED1B9
No error codes found.
Address 03: Brake electronics
Label file: DRV\8E0-614-111-EDS.lbl
Part number: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Operating number: BB 24334
VCID: 1C3DDE3AA63B
Address 08: Climate Control Module. Label file: DRV\3Bx-907-044.lbl.
Part number: 3B1 907 044 B
Component: CLIMATRONIC Version 1.0.0
Encoding: 05000
VCID: 2045EACA8A53
"One error found:"
00792 - Pressure switch for air conditioner (F129)
35-00 - -
Address 15: Airbag
Encoding: 12341
VCID: 36692C9238D7
Address 17: Control panel module
Label file: DRV\3B0-920-xx2-17.lbl
Part number: 3B0 920 842 A
Bauteil: B5-KOMBIINSTR. VDO V16
Coding: 21365
Operating number: WSC 76538
VCID: 1F47E936B72D
Part number: IMMO
Component: IDENTIFICATION NUMBER: VWZ7Z0X1782132
IMMO IDENTIFICATION NUMBER: VWZ7Z0X1782132
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Coding: 00005
Operating number: WSC 05314
VCID: F0E55A8A9A33
Address 37: Navigation
Label file: DRV\3B0-919-887.lbl
Part number: 3B0 919 887 E
Component: Navigation BNO 0304
Encoding: 00002
Operating number: WSC 76091
VCID: 346D169A2EAB
Address 46: Comfort System
Label file: DRV\1J0-959-799.lbl
Part number: 1J0 959 799 AH
Component: 33 Central SG Comfort Unit 0001.
Encoding: 04096
VCID: 840D065ABE8B
Part number: 1J1959801D
Bauteil: 33 TÔrsteuerger. FS0002r
Part number: 1J1959802E
Bauteil: 33 TÔrsteuerger. BF0002r
Part number: 1J4959811D
Bauteil: 33 TÔrsteuerger. HL0002H
Part number: 1J4959812D
Bauteil: 33 TÔrsteuerger. HR0002r
3 error codes found:
00912 - Front left window switch (E40)
27-10 - implausible signal - sporadic.
00913 - Window switch for front right window; driver's side (E81).
00930 - Rear left central locking control unit (F222)
Address 55: Headlight range control. Label file: DRV\4Z7-907-357.lbl
Part number: 4Z7 907 357.
Component: dynamic LWR, D07.
Coding: 00008
VCID: 040D865A3E8B
Address 56: Radio Label file: DRV\3B0-035-186.lbl
Part number: 3B0 035 186 D
Component: Radio BNO 0304
Encoding: 05407
VCID: 2045EACA8A53
"One error found:"
00856 - Antenna; for the radio.
36-00 - Interruption.
End.
FIN: WVWZZZ3BZYE072830
What would be the sensible thing to do? Should I go to VW and buy the control unit there, for a multiple of the price?
On eBay, you can find these control units for around 50 euros, even from vehicles that haven't been in accidents.
Translated on 25-08-2026, 22:03.
05-05-2011, 7:47 Subject: Airbag Control Unit: Coding Only? |
VW explicitly prohibits the installation of used airbag components. However, since the manufacturer's guidelines are legally binding, it raises questions about whether installing a used control unit is even legal. In practice, you can check the origin and history of the control unit, for example, whether it has already been deployed or not. The discussion about used control units has already been extensive, but we do not support it â especially not without proof of the necessary authorization.
P.S.: By the way, the airbag control unit is also no longer available for new orders. The part number 6Q0-909-605-B-005 has been replaced multiple times, and the current part number is 1C0-909-605-B-00E.
Translated on 30-10-2026, 3:30.
3BPassatV6
05-05-2011, 14:09 Subject: Airbag Control Unit: Coding Only? |
@ Sebastian
You're right. If I were to order the control unit now, I would have to use the part number you provided.
However, that doesn't change the fact that a used, unused part with my part number and the correct (my old) coding should work with my system - or am I mistaken?
Translated on 30-10-2026, 3:32.
