Joined: 04/12/2002 Posts: 18130 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
27-09-2011, 10:53 Subject: Throttle valve basic setting not possible, 1.8L R4/5V AGN |
With an AGN motor, it is not possible to perform a basic throttle adjustment.
The throttle body was disassembled, cleaned, and reassembled, but the car is not currently in my possession.
The reason for the breakdown was "stuttering at certain load points."
Could it be that the initial setup is not possible due to an incorrect "Maximum Throttle Potentiometer Setting," meaning it's somehow incorrectly assembled?
In measurement block 23, the "Maximum throttle potentiometer position" is indicated as 42.7°.
Bitmask 001110: according to the label file:
- Throttle potentiometer alignment not okay; mismatch with idle control potentiometer.
- Learning process: Maximum voltage reached, DK potentiometer not functioning correctly.
- Learning process for minimum threshold DK-potentiometer not working correctly.
- Learning process: Maximum throttle setting error, idle speed control potentiometer not functioning correctly.
Code: | Dienstag,27,September,2011,09:02:56:37095
VCDS Version: RKS 10.6.4
Datenstand: 20110418
Adresse 01: Motor Labeldatei: RKS\06A-906-018-AGN.LBL
Steuergerät-Teilenummer: 06A 906 018 CL
Bauteil und/oder Version: 1,8l R4/5V MOTR HS V02
Codierung: 04000
Betriebsnummer: WSC 00000
VCID: 6ED6496F0007
2 Fehler gefunden:
17973 - Drosselklappensteuereinheit (J338): unterer Anschlag wird nicht erreicht
P1565 - 35-00 - -
17967 - Drosselklappensteuereinheit (J338): Fehler in Grundeinstellung
P1559 - 35-00 - -
Readiness: Nicht verfügbar |
Profile PM WWW Garage |
Deus Violentia Schrauber
27-09-2011, 20:13 Subject: Throttle valve basic setting not possible, 1.8L R4/5V AGN |
The procedure varies depending on the protocol, but generally, for electrically actuated disconnectors, it is as follows:
KWP-1281:
01 --> Measurement block
08 --> 060 --> Basic setting
--> Start
--> Wait 30 seconds, adaptation is running
--> Switch to normal measurement block
--> Done, return.
KWP-2089:
01 --> Default setting 04 --> 060 --> Start --> "Default setting OFF" --> on/off/continue --> "Default setting ON" --> Cycle runs, stops, leave "Default setting ON" for 30 seconds --> on/off/continue --> "Default setting OFF" --> finished, return.
Please provide the German text you would like me to translate into English.
Carefully check the adjustment mechanism of the variable intake manifold, even if the electric valve is working! Very often, the linkage is misaligned, which can lead to these kinds of problems, and the car also consumes at least 1 liter more fuel. BKD GRF
AHF EBF
28-09-2011, 10:56 Subject: Throttle valve basic setting not possible, 1.8L R4/5V AGN |
Quote: |
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
"Can you tell me where I can find the rice husk pipe?" Is this part of the throttle body?
> Yesterday, I opened the throttle body cover again and noticed that the initial setting sometimes...
> it works. In case of a fault, the adjustment is blocked before reaching the end stop, and it will no longer proceed. ==> Also with...
> I don't offer tutoring. ==> Is the adjustment motor a stepper motor? |
The N156 valve, which controls the vacuum switching for the intake manifold, is located: When you are standing in front of the engine and looking at the exhaust manifold, it is on the right-hand side, at the top front, next to the manifold. It should have a resistance of approximately 30 Ohms, plus or minus 5 Ohms.
Functional test of the intake manifold switchover:
- Engine is idling.
- Suddenly accelerate to full speed.
- The vacuum sensor on the intake manifold needs to be tightened.
The N156 can also be accessed and tested using the VCDS actuator test function.
The intake manifold switching valve is located in the intake manifold.
I'm not sure about that, as I haven't disassembled one before. In the case of 2.0 TDI diesel engines, the plastic gears in the AGR/throttle valve often break.
29-09-2011, 9:02 Subject: Throttle valve basic setting not possible, 1.8L R4/5V AGN |
Current status:
Quote: | Meanwhile, I have replaced the throttle valve.
> because I considered the blocking that was described yesterday to be unacceptable. The basic settings are now correct, and the following issues are occurring:
> Currently, there are no more error messages appearing during the ride. The stuttering is now less severe, but it is still very disruptive.
> It's clear that there's still a second error present.
I will now address the valve for the vacuum-operated bypass control.
> accept. |
29-09-2011, 10:11 Subject: Throttle valve basic setting not possible, 1.8L R4/5V AGN |
It's important not only to check the valve itself, but especially the adjustment mechanism! BKD GRF
AHF EBF
06-10-2011, 10:26 Subject: Throttle valve basic setting not possible, 1.8L R4/5V AGN |
Brief feedback on the variable intake manifold: Difficulty shifting due to a very conservative driving style. After some "use," the car now runs smoothly without any jerking.
