GRA installation on the Passat 35i TDI 1Z: Steering wheel switch ...
WarLord
Post26-07-2003, 17:29    Subject: GRA installation on the Passat 35i TDI 1Z: Steering wheel switch ... Quote
Found at a bargain price, but unfortunately, no cable was included. Do I have to buy the cable separately from VW, or can I assemble it myself?
Best regards, WarLord
Post27-07-2003, 10:54    Subject: GRA installation on the Passat 35i TDI 1Z: Steering wheel switch ... Quote
I had my VW GRA (which I had negotiated as part of the purchase) transferred to a new owner.
m.W. has even made the cable himself in the workshop, although it should have been included in the "retrofit kit".
You will, however, likely find that you cannot solder the parts together.
WarLord
Post27-07-2003, 18:14    Subject: GRA installation on the Passat 35i TDI 1Z: Steering wheel switch ... Quote
Is the cable 1:1 connected?
Albrecht
Post27-07-2003, 18:36    Subject: GRA installation on the Passat 35i TDI 1Z: Steering wheel switch ... Quote
must be soldered, nothing else. This cable is only a cable extension.
4 Cables 1:1. "That will certainly be a challenge, especially when searching for the correct connector behind the main electrical panel if you don't know what it looks like icon_smile.gif."
Best regards
Albrecht
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts FSE PREMIUM in Passat, Golf, Tiguan nachrüsten Troubleshooting & Guides
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Wieviel kostet der GRA Lenkstockschalter für einen Passa... Diesel Engine Technology
No new posts Retrofit Passat 3BG Electric Folding Mirrors On-Board Diagnostics (OBD)
No new posts Retrofit MFA on a Passat 35i TDI 1Z Special Model Court Diesel Engine Technology
No new posts Aero Wiper Blades: Retrofit for VW Passat 98 Transmission, Chassis, Body & Interior
