Audi A4: Retrofit On-Board Computer (B4 97)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
TDI Kraft ohne Ende
Post26-07-2003, 2:11    Subject: Audi A4: Retrofit On-Board Computer (B4 97) Quote
javascript:emoticon('icon_question.gif')Hello
I obtained a display with a board computer (FIS) from an Audi A4 manufactured in 1996.
'The connectors fit perfectly, and it's working well now, except for...'
the radio display on the screen.
The radio (AUDI Gamma) is transmitting the signals; I tested this on an A6 model from 1998.
My questions.
'Does anyone have the encoding data for the display from a 1996 model? I only have the data for the display from a 1997 model.'
Do radio and FIS (presumably referring to a specific system or technology) even work together in this way?
Or does one still need to adjust any settings on the display?
Thank you very much.
Translated on 08-09-2026, 0:34.
davidshoes
Karma: +6 / -2   Thank you, like it!
Post26-07-2003, 14:58    Subject: Audi A4: Retrofit On-Board Computer (B4 97) Quote
Take a look at the FAQ section on www.audi4ever.at; someone has written a description about how to retrofit the FIS (driver information system).
Translated on 08-09-2026, 0:35.
TDI Kraft ohne Ende
Post27-07-2003, 20:16    Subject: SEO-Optimized Title: "Best SEO Tools: Improve Your Rankings Now" Quote
Hello.
Thanks for the tip. I've now connected all the functions, and they're working quite well. The power consumption display is still a bit glitchy (it stubbornly holds onto the last value when the system is idle), but otherwise, it's okay.
Thank you again.
Translated on 08-09-2026, 0:36.
davidshoes
Post27-07-2003, 22:49    Subject: Audi A4: Retrofit On-Board Computer (B4 97) Quote
They always do that with the fuel consumption figures! Only VW switches to liters per hour when the car is stationary.
Translated on 08-09-2026, 0:37.
No new posts LED Rückleuchten Retrofit for Audi A6 4F Saloon Troubleshooting & Guides
No new posts VCDS: On-board diagnostics for VAG vehicles Troubleshooting & Guides
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Switch option for on-board computer levels On-Board Diagnostics (OBD)
No new posts Nachrüsten eines Kombiinstrumentes Diesel Engine Technology
No new posts Aftermarket Height Sensors (F96) Golf TDI MKB 1Z, Year 1995 On-Board Diagnostics (OBD)
No new posts Retrofitting the passenger airbag switch in the A4 Electrical Systems, Vehicle Electronics, Multimedia
