Tiptronic Transmission Problems: Troubleshooting Guide
awissus001
Karma: +0 / -1   Thank you, like it!
Post01-11-2011, 19:34    Subject: Tiptronic Transmission Problems: Troubleshooting Guide Quote
Address 02: Transmission Label file: RKS\01V-927-156.lbl
Control unit part number: 3B0 927 156 L.
Component and/or version: AG5 01V 2.5l TDI, Roadworthy, production date 9404.
Encoding: 00000
Company number: WSC 00000
VCID: 2F67636DC786
"One error found:"
18265 - Malfunction indicator light: Error message from the engine control unit.
P1857 - 35-10 - - - Sporadic
The transmission only works for a short time, then it jerks, and then it goes into emergency mode.
The fuel injection pump is new and has an error: "Injection start timing difference." However, the pump is set to Top Dead Center (TDC) and is within the tolerance of 1.6 degrees before TDC. What could be broken? I'm at a loss.
Translated on 29-10-2026, 20:49.
michiglaser
2007 Audi A4 Avant
Post01-11-2011, 22:28    Subject: Tiptronic Transmission Problems: Troubleshooting Guide Quote
Is there an error code stored in the engine control unit (ECU)?
Otherwise, I would check the cable from the alternator to determine the generator's load.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 29-10-2026, 20:50.
mullemaus
Post01-11-2011, 23:41    Subject: Tiptronic Transmission Problems: Troubleshooting Guide Quote
The load signal error is not related to the Lima (alternator), but rather to the load itself, such as torque, etc. In the case of V6/TT5 engines specifically, also check the mass airflow sensor (MAF).
Translated on 29-10-2026, 20:51.
awissus001
Post16-11-2011, 14:21    Subject: Tiptronic Transmission Problems: Troubleshooting Guide Quote
"I've now found and fixed the problem. I had some old summer diesel fuel in the tank because the vehicle had been sitting for a long time and wasn't put back into operation until the end of October. Now that I've removed everything (siphoned it out), replaced the filters, and bled the system, it's running perfectly, and there are no more error messages in the MST (diagnostic system). I was misled because a new fuel injection pump had been installed just 300 km ago. I thought it was faulty again and attributed the error in the MST (a "regulation difference" error) to it. Well, now everything is fine again."
Translated on 29-10-2026, 20:52.
awissus001
Post16-11-2011, 14:24    Subject: Tiptronic Transmission Problems: Troubleshooting Guide Quote
Hello.
Sorry for the typos. MST stands for Motor Steuergerät (Engine Control Unit).
Translated on 29-10-2026, 20:53.
Post16-11-2011, 16:21    Subject: Tiptronic Transmission Problems: Troubleshooting Guide Quote
awissus001
Post18-11-2011, 21:31    Subject: Tiptronic Transmission Problems: Troubleshooting Guide Quote
"I'm now driving 30 to 50 km every day, and so far I haven't experienced any more jerking or erratic shifting. In my opinion, that was actually the problem. I'm lucky again."
No new posts Document LT 28, Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Audi A2 to A6, Gearbox Area, Customer Goodwill Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power consumption with PÖL higher / how does the power c... Diesel Engine Technology
No new posts AFN: Smoke blowing from the engine, cylinder 1 not working Upload
No new posts Automatic Transmission AFN: Oil Change, Gearbox. Diesel Engine Technology
No new posts Tiptronic On-Board Diagnostics (OBD)
