Passat V6 TDI Won't Start: Error Code 1044
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
ahkspezialist
Post17-11-2011, 12:31    Subject: Passat V6 TDI Won't Start: Error Code 1044 Quote
I'm slowly starting to despair.
My Passat V6 TDI (engine code: AKN, transmission code: ETZ, chassis number: 3BZYE402169, first registration: 06/2000) had a problem with the fuel injection pump some time ago, which I have since replaced. After painstakingly bleeding the fuel system and installing a new fuel pump in the tank, the engine ran both when stationary and while driving in our large courtyard. To properly recharge the battery and check for any error codes, I let the car run for about 1 hour. When I then gave it some gas to drive into the garage, it stalled and hasn't started since.
The following message appeared via VCDS (and the Bosch tester also shows "Error 01044: Control unit incorrectly coded"):
Thursday, November 17, 2011, 10:08:21:62451
VCDS Version: RKS 10.6.5
Data as of: 20110418.
Vehicle type: 3B - VW Passat B5.
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 181,940 km
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine, Label file: RKS\059-907-401-AKE.lbl
Part number: 3B1 907 401.
Part number: 2.5l/4VTEDC 0000AG D02
Encoding: 03011
Operating number: WSC 53141
VCID: DBBE7B3163BE
000000059130106CXC150_1.V5A298864887
No errors found.
Readiness: Not available.
Address 02: Transmission Label file: RKS\01V-927-156.lbl
Part number: 8D0 927 156 CQ
Part number: AG5 01V 2.5l TDI, Roadworthy certificate 3131.
Encoding: 00103
Operating number: WSC 05311
VCID: 7EF892A5506C
No errors found.
Address 03: Brakes
Label file: RKS\8D0-907-389.lbl
Part number: 8D0 907 389 D
Component: ABS/ESP front D36
Encoding: 04257
VCID: 346C708D2EA0
No errors found.
Address 08: Climate Control/Heating. Label file: RKS\3Bx-907-044.lbl.
Part number: 3B1 907 044 D
Component: CLIMATRONIC D2.2
Encoding: 05000
VCID: 224086D58454
4 errors found:
01273 - Fresh air blower (version 2)
35-10 - - - Sporadically
01206 - Signal for ignition deactivation duration.
00532 - Power supply voltage.
07-10 - Signal too weak - Sporadic.
00281 - Vehicle speed sensor (G68)
35-00 - -
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 605 B
Part: 05 AIRBAG VW5 0004
Encoding: 12341
VCID: 36684A8538DC
No errors found.
Address 17: Combination instrument
Label file: RKS\3B0-920-xx2-17.lbl
Part number: 3B0 920 822 A
Component: COMBINATION INSTRUMENT + TRIP COMPUTER, BOO V21.
Encoding: 05165
Operating number: WSC 00000
VCID: 1D3AB529BD2A
Part number: Ident
Part number: VWZ6Z0Y1773092
Identification Number: VWZ6Z0Y1773092
"One error found:"
01039 - Coolant temperature sensor (G2).
64-10 - Currently not verifiable - Sporadic.
Address 19: CAN-Gateway
Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Coding: 00005
Operating number: WSC 05314
VCID: F0E43C9D9A38
"One error found:"
01044 - Control unit incorrectly coded.
35-00 - -
Address 46: Comfort System
Label file: RKS\1J0-959-799.lbl
Part number: 1J0 959 799 AH
Component: 33 Central SG Comfort Unit 0001.
Encoding: 04097
VCID: 840C604DBE80
Part number: 1J1959801D
Bauteil: 33 TÔrsteuerger. FS0002r
Part number: 1J1959802E
Bauteil: 33 TÔrsteuerger. BF0002r
Part number: 1J4959811D
Bauteil: 33 TÔrsteuerger. HL0002r
Part number: 1J4959812D
Bauteil: 33 TÔrsteuerger. HR0002r
No errors found.
Address 47: Soundsystem
Label file: RKS\1J0-035-456.lbl
Part number: 1J0 035 456.
Component: Sound processor 3 0005.
Coding: 00581
VCID: E2C046D544D4
No errors found.
Address 56: Radio
Label file: RKS\1J0-035-18x-56.lbl
Part number: 1J0 035 186 D
Component: RADIO SON 0003
Coding: 00023
VCID: 26489AC5E87C
No errors found.
End.
Who can help me? What should I do?
Sure, here is the translation of the German text into English:
"Please provide instructions on how to proceed in VCDS (I am new to it)."
Here are some general instructions on how to proceed in VCDS:
1. **Connect your VCDS device to your car's OBD-II port.**
2. **Turn on your car's ignition.**
3. **Open the VCDS software on your computer.**
4. **Select the appropriate vehicle model and year from the VCDS menu.**
5. **Choose the desired function from the VCDS menu.**
6. **Follow the on-screen instructions to complete the task.**
If you are unsure about any of the steps, please consult the VCDS user manual or contact VCDS support for assistance.
Sure, here's the translation:
"Thank you in advance."
"Hello"
Joe.
Translated on 27-08-2026, 21:48.
Post17-11-2011, 12:43    Subject: Passat V6 TDI Won't Start: Error Code 1044 Quote
Check pump status!
/viewtopic.php?t=23024
Regarding the gateway: The correct encoding would be 00006.
Translated on 27-08-2026, 22:00.
ahkspezialist
Post17-11-2011, 13:27    Subject: Passat V6 TDI Won't Start: Error Code 1044 Quote
Thank you for the quick response.
Pump status checked, no errors 00000000.
Okay, I then went to the control unit selection, called up "Can_Bus," and then "Coding." I changed the coding as suggested to 00006 and then clicked "Code," but VCDS has been running for half an hour now, and it still shows 00005. Do I need to log in beforehand? If so, how?
Thank you.
Joe.
Translated on 27-08-2026, 22:01.
ahkspezialist
Post17-11-2011, 13:30    Subject: Passat V6 TDI Won't Start: Error Code 1044 Quote
I've also noticed something else, but I'm not sure if it's related:
The workshop code is 05311 for the engine, transmission, etc., but 05314 for the CAN gateway, and 00000 for the WFS.
Translated on 27-08-2026, 22:02.
Post17-11-2011, 13:55    Subject: Passat V6 TDI Won't Start: Error Code 1044 Quote
Damn, my mistake. It has an automatic transmission. Then she needs to set it to 00007.
Regarding the engine: Does absolutely nothing happen when you try to start it, or does it at least occasionally spark?
Have you ever considered having a second person check the transparent diesel line for air bubbles when starting the engine, or to verify if fuel is actually being pumped?
Translated on 27-08-2026, 22:03.
Post17-11-2011, 14:26    Subject: Passat V6 TDI Won't Start: Error Code 1044 Quote
The workshop code indicates who last worked on it; why do you want to change that?
Translated on 27-08-2026, 22:04.
ahkspezialist
Post17-11-2011, 19:51    Subject: Passat V6 TDI Won't Start: Error Code 1044 Quote
Hello Rainer,
I don't want to change anything, I just noticed it. As I mentioned before, I'm not yet proficient with VCDS (but I'm knowledgeable about BOSCH KTS), and I was wondering if it has any significance. So, I'll just leave it alone.
Thank you.
Joe.
Translated on 27-08-2026, 22:05.
Post17-11-2011, 21:38    Subject: Passat V6 TDI Won't Start: Error Code 1044 Quote
You could try loosening a check nut on the injectors during the starting attempt to see if any fuel is being injected.
Based on the described symptoms, I suspect there's an air leak in the fuel system.
ahkspezialist
Post19-11-2011, 11:26    Subject: Passat V6 TDI Won't Start: Error Code 1044 Quote
Thank you for the tip.
Okay, I've now loosened the bleed valve on each cylinder bank one by one, and when I try to start the engine, nothing happens. However, I can't see any air bubbles in the fuel line leading to the pump. The ESP (electric fuel pump), the filter, the fuel line from the filter to the ESP, and the fuel pump unit in the tank are all new, and the car was running fine for a while. Could it be that there's something wrong with the WFS (fuel supply module) causing the error code 1044 and preventing the fuel from being pre-pressurized?
"Hello"
Joe.
Translated on 27-08-2026, 22:07.
Post19-11-2011, 12:57    Subject: Passat V6 TDI Won't Start: Error Code 1044 Quote
Address 19: CAN-Gateway Label file: RKS\6N0-909-901-19.lbl
Component: Gateway K<->CAN 0001.
Coding: 00005
Operating number: WSC 05314.
VCID: F0E43C9D9A38
"One error found:"
35-00 - -
Could it be that there is something wrong with the WFS, which is why error code 1044 is appearing and no pre-processing is taking place?
Probably not, it's a different issue. To put it bluntly: Then just code it correctly, it's not magic at the gateway.
However, there are absolutely no air bubbles visible in the fuel line leading to the pump. The ESP (Electronic Stability Program), the filter, the fuel line from the filter to the ESP, and the lift pump in the tank are all new.
Does this mean they are now filled with fuel or are they empty?
Is the fuel pump now filled with diesel, or not? If it's not drawing fuel, it's either defective or clogged.
Translated on 27-08-2026, 22:09.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post19-11-2011, 17:26    Subject: Passat V6 TDI Won't Start: Error Code 1044 Quote
Who changed the ESP, and was it properly bled?
The VP44 is quite susceptible to air exposure, which can quickly lead to problems.
Translated on 27-08-2026, 22:11.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0299 Error: Boost Control System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P068A Error: Engine Won't Start (Relay J271) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B AHU won't start Diesel Engine Technology
No new posts Passat, manufactured in 1994, engine 1Z stalls and won't ... On-Board Diagnostics (OBD)
No new posts Passat Starting Problems: No Error Code, Help! Diesel Engine Technology
No new posts Audi Q7: Won't Start - Troubleshooting Guide Diesel Engine Technology
