Hi Georg!
No problem, the engine oil does not need to be drained before removing the cylinder head.
However, an oil change should be performed afterwards - that's a given.
However, some engine oil residue always remains in the ZK (oil separator), which doesn't drain back into the oil pan â it's probably around 50-100 ml.
Therefore, during the dismantling process, something will inevitably come loose, which unfortunately cannot be avoided.
Best regards from Munich!
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger!
