Uneven brake wear
menzinger68
Post24-10-2011, 14:53    Subject: Uneven brake wear Quote
"The brakes on my Audi A4 quattro are squealing, but the warning light hasn't come on. However, a visual inspection revealed that only the rear right brake is affected. The brake pads were completely worn down, and the rotor is scored." The other three still have over 70%.
Topping.
Exchanging it won't be a problem. But what is the cause of the uneven braking?
Thomas.
Audi A4 Avant, 2,5 TDI V6 , BJ 1999, Motor AFN
Getriebe DAJ DEY
Post24-10-2011, 14:59    Subject: Uneven brake wear Quote
Seized pistons?
brezelmann01
Post24-10-2011, 15:27    Subject: Uneven brake wear Quote
Most often, the brake pad guide is covered in rust, which prevents the pads from retracting properly. The wear sensor is likely only located on the front left of your vehicle, which is why the check light isn't illuminated.
Best regards.
Karma: +1100 / -0   Thank you, like it!
Post24-10-2011, 16:37    Subject: Uneven brake wear Quote
The approach outlined by Brezelmann is initially the correct solution! Remove the brake pads on both sides, take out the linings, and carefully remove any rust from the lining guides. Because the linings are worn unevenly, replace all of them and reassemble them with a little ceramic paste in the lining guides. This assumes that the brake discs are not damaged and do not yet require replacement due to their material thickness. Please also inspect the glass for hairline cracks.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post24-10-2011, 17:34    Subject: Uneven brake wear Quote
Check the brake caliper for ease of movement, then replace the pads and rotors. The brake pads will definitely not retract; when the brake is released, only the pressure on the brake disc is relieved, and depending on the ease of movement, the pads will still drag more or less.
reflexsilber met.
brezelmann01
Post24-10-2011, 17:40    Subject: Uneven brake wear Quote
"I apologize for my imprecise wording icon_rolleyes.gif"
menzinger68
Post24-10-2011, 18:13    Subject: Uneven brake wear Quote
Thank you for the tips. I'm more inclined to think it's a seized piston. On the last trip, the affected brake seized while parking, specifically while reversing. It wasn't until a guest appearance that things started to look up again.
Saddles are not as expensive in this area. If I need to replace one saddle, should I also replace the other saddle on the same axle?
Thomas.
PS: I wrote a post earlier, but it seems it has been deleted. Perhaps because I...
I wrote to a prominent internet shareholder. Or?
Getriebe DAJ DEY
olli
Karma: +46 / -0   Thank you, like it!
Post26-10-2011, 16:30    Subject: Uneven brake wear Quote
If those are the same saddles as used in the C4, then there's a 99% chance that the saddle rails are seized.
Remove any grease or grime from the brake caliper mounting bracket using a scraper (a drill bit can also work in a pinch), and clean the bolts as well. If necessary, use sandpaper to clean them, or replace them altogether.
Then, reassemble everything, adding a little lubrication.
"I had a similar issue with my C4. The problem was that the workshop, in their wisdom, replaced the brake pads without checking the free movement of the guide pins. During a ski trip, one of the pads disintegrated, and the rotor started sparking..."
Fortunately, this happened only in the last few kilometers before reaching home; I wouldn't have wanted that in the mountains...
Best regards from Berlin,
olli
A6 CANA/JME /
Ex-A6 AEL
heizfoss
Karma: +4 / -1   Thank you, like it!
Post05-11-2011, 0:06    Subject: Emergency brake fault Quote
I also experienced this problem with my Passat 35i and my Audi 80. I just replaced a saddle for that reason.
The handbrake mechanism on the rear calipers was stuck/difficult to operate. This prevents the handbrake from fully releasing. There remains a residual force – approximately one "click" of the handbrake lever. As a result, the brakes overheat and wear out. You don't really notice it when you're driving.
As far as I can see, the C4 has a similar principle and known issues.
Okay, ich bin bereit. Bitte gib den deutschen Text ein.
http://www.daparto.de/Artikeldetails/e79c86ac242ae307e20cf9478741e5a41a8f1607
Problems:
http://audi100.selbst-doku.de/Main/KaufberatungUndPreiseC4
Try releasing the parking brake lever and testing its operation. See how easily it moves; it should be easier to operate on the working brake – especially when returning it to the unengaged position.
heating fossil.
icon_smile.gif Spritsparen durch Ausnutzen der Querbeschleunigung - lieber tot als Schwung verlieren
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post02-12-2011, 10:22    Subject: Uneven brake wear Quote
It's quite rare for the brake caliper pistons to seize up on newer Audi models.
Often, these two guide pins corrode and become stuck.
That car tends to pull to one side when braking hard.
I cleaned and greased these bolts with special grease four years ago, and it's been quiet ever since.
No new posts Document Transporter 7D, vehicle braking unevenly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Worn clutch disc pressure plate bearing, Golf/Bora 85KW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Rear brakes not engaging properly on VW Golf G4 Transmission, Chassis, Body & Interior
No new posts Climate Control Malfunction: Photosensor Issue Transmission, Chassis, Body & Interior
No new posts Uneven Tire Wear: Causes & Solutions Transmission, Chassis, Body & Interior
No new posts Passat NW worn out Diesel Engine Technology
