Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD)
Karma: +1344 / -0   Thank you, like it!
Post08-02-2012, 10:57    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
The nozzle tip of the ESD (Electrostatic Discharge) device, along with the NHG (likely referring to a specific material or component), should be placed in the ultrasonic cleaning bath.
Background: The LLR (Low-Level Regulator) is showing fluctuating readings of 1.5 - 2 mg/stroke too high for this ESD (Electronic Spray Deflector). The limit according to the manufacturer's specifications is 1.5 mg/stroke. The compression is approximately the same (+/- 1 bar) on all cylinders, so it's not a compression issue. It's not the pressure equalization valves either, as the problem persists even with a new ESP (Exhaust Gas Recirculation) unit. The injection pressure is around 190 bar (similar to a second ESD on the engine for comparison). The spray pattern is noticeable at higher injection rates; it sometimes doesn't atomize properly.
I follow the instructions for disassembly in https://community.dieselschrauber.org/en/viewtopic.php?t=10197.. However, I am missing the tightening torque for the nozzle tip's union nut. Can anyone help me with that?
Sure, here's the translation:
"Best regards," or "Sincerely,".
Translated on 01-10-2026, 10:42.
Post08-02-2012, 12:06    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
Hello Herbert,
I can't provide precise values, but you'll feel a point where it can't be tightened any further.
If you don't want to upset your mother, then you should just leave it as it is.
It's quite tight, so a ring wrench or socket is necessary. A combination wrench won't provide enough torque. The best approach is to use the loosening torque when unscrewing as a reference point.
PS: I might still have some spare nozzles lying around; please let me know the number printed on the nozzle.
Translated on 01-10-2026, 10:44.
Post08-02-2012, 20:35    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
Hello Rainer,
The part number is 028 130 201 H or HX. Bosch refers to it as 0 432 193 837.
I recently found a torque specification of 33 ft lb (approximately 45 Nm) on a North American website, referencing a Bosch workshop.
Translated on 01-10-2026, 10:45.
Post08-02-2012, 21:01    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
I meant the number on the nozzle, not on the nozzle holder icon_smile.gif.
Here's another tip: After 1-2 rotations, give the nozzle tip a firm tap (with wood, if you want to reuse it), otherwise, carbon buildup can cause the nozzle tip to rotate and the guide pins can break off.
Translated on 01-10-2026, 10:46.
Post08-02-2012, 23:30    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
Hello Rainer,
First of all, thank you for the advice. I will take extra care and be very gentle when disassembling it.
The ESD (Electronic Stability Device) is still installed, but the vehicle will definitely still run until the weekend.
From DieselSend, I have the following part numbers for the injector holder combination 0 432 193 837:
Bosch DSLA150P357 (0 433 175 058), Repair kit 2 437 010 083.
Translated on 01-10-2026, 10:47.
Post10-02-2012, 16:22    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
DSLA150P357
Too bad, none left.
Translated on 01-10-2026, 10:48.
Post10-02-2012, 20:33    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
Nevertheless, icon_thanks.gif for verification.
The nozzle should be resistant to alcohol (I wanted to use it in an ultrasonic cleaner), right?
Post10-02-2012, 21:22    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
Herbert wrote:
The nozzle should be resistant to alcohol (I wanted to use it in an ultrasonic cleaner)?
Yes, but don't get your hopes up too much...
Translated on 01-10-2026, 10:49.
Post12-02-2012, 0:04    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
The ESD (Electrostatic Discharge) protection is installed and dismantled.
Before loosening the retaining nut, it's best to carefully clean the area between the nut and the nozzle tip with the brass brush.
After loosening, the mother gently rotates the coal back and forth, which dissolves the coal in that area.
The nozzle tip was thoroughly cleaned in the ultrasonic bath, and all carbon deposits are gone. However, it requires multiple cleaning cycles. Cleaning with alcohol (ethanol) is less effective than cleaning with water.
After the initial cleaning, I used alcohol to remove any remaining water residue. I cleaned the other parts in the ultrasonic cleaner only with alcohol for that reason.
The structure of the ESD is https://community.dieselschrauber.org/en/viewtopic.php?t=7444 well illustrated, but the guide bushing 8 encloses the upper spring 6, and there is a washer between the lower spring 6 and the pin 2.
Under the magnifying glass, all parts are clean after the ultrasonic bath. It's best to leave them as they are, as each cloth leaves lint behind.
(Modified) The pattern of the five holes on the cone of the nozzle tip is asymmetrical. One hole is near the tip of the cone, the two adjacent holes on the left and right are deeper, and the last two are near the base of the cone. I suspect that this is related to the angled mounting position of the ESD in the ZK (control unit). In other words, the nozzle tip is aligned so that the injection holes are equidistant from the ZK? The alignment is determined by the pins of the intermediate disc.
Translated on 01-10-2026, 10:51.
Post12-02-2012, 13:29    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
In other words, the nozzle tip is oriented such that the injection holes are equidistant from the center line?
Translated on 01-10-2026, 10:53.
Post13-02-2012, 23:36    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
The ESD has been reassembled and installed back into the engine.
I had marked the position of the retaining nut relative to the nozzle holder before disassembling it. When the tightening torque is 40-45 Nm, the markings align again.
For those who might need a reminder, here's a summary:
- Carefully clean the nozzle throat in the area of the female thread with the brass brush before loosening (the nozzle here was only slightly clogged with carbon deposits, except for some individual holes).
- Secure the nozzle in the vise using appropriate aluminum profiles on the sides.
- To loosen the nut, use a long socket wrench with a 15mm socket, such as a Proxxon. Using an open-end wrench is pointless, as it will only damage the nut. A box-end wrench will also likely slip and damage the sides.
- After the initial loosening, gently move the mother plant back and forth before continuing to carefully separate it.
- The nozzle, spacer plate, and nozzle holder will inevitably be contaminated with leaked diesel fuel (DK) and soot when the nut is loosened. Cleaning in an ultrasonic bath is essential.
- Water cleans better in an ultrasonic bath than alcohol, but because of the potential for water residue, I only used it on the nozzle itself, and then cleaned it again with alcohol at the end.
- Before assembly, apply a small amount of diesel to all parts.
Unfortunately, the results were quite moderate. The LLR values only improved slightly, but the nozzle is clogged when it's warm, so I'll probably have to replace it.
Translated on 01-10-2026, 10:55.
Post17-02-2012, 11:05    Subject: Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Quote
After one week / approximately 300 km of operation, the LLR (lithium-ion battery life) has improved significantly.
Cylinder #3 is still slightly weaker, but the deviations are now only 0.8 - 1.0 mg per cycle, and even lower, at 0.3 mg per cycle, after starting the engine (all with a warm engine).
The tolerance limit would be 1.5 mg per click.
The nozzle is no longer secured with nails.
Immediately after reinstallation, I observed a deviation of between 1.6 and 1.9 mg per injection.
The ESD (electrostatic discharge) was slightly weaker (approximately 1 mg per port) from the moment of installation, with very consistent compression values.
I'm satisfied with it for now.
Translated on 01-10-2026, 10:59.
No new posts Cylinder Head Bolt Torque Specs 1Z Diesel Engine Technology
No new posts Crankshaft bolt torque specification ALH G4 Diesel Engine Technology
No new posts Tightening Torque: 16V PD Camshaft Diesel Engine Technology
No new posts Torque Specs: Pulley & Seal for 1Z Engine Diesel Engine Technology
