RKA Retrofit for 1K0 907 379 AC
Post17-08-2009, 15:08    Subject: RKA Retrofit for 1K0 907 379 AC Quote
Can the RKA (Rear Collision Avoidance) system be easily retrofitted to this ABS/ESP system using buttons and coding?
Code:
Adresse 03: Bremsen/ABS       Labeldatei: RKS\1K0-907-379-MK60-F.LBL
   Teilenummer SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Bauteil: ESP FRONT MK60      0101
   Codierung: 0021121
   Werkstatt #: WSC 01279
Translated on 31-08-2026, 6:13.
Post17-08-2009, 20:29    Subject: RKA Retrofit for 1K0 907 379 AC Quote
If no one else responds:
Have you tried the encoding yet?
If not: First, try encoding.
If that works: Simply plug a yellow wire into the ABS control unit and connect it to the car body. If you then hear a "ping" from the instrument cluster, I would suggest test driving it. If it works, extend the yellow wire into the interior.
Good luck!
Post18-08-2009, 7:09    Subject: RKA Retrofit for 1K0 907 379 AC Quote
For the Passat, it's "add 2048".
I vaguely remember that in golf, it's not about *setting* a bit, but rather *clearing* it, meaning subtracting something.
Unfortunately, I can't find that guide anymore. I got it from some forum, maybe something like MT or Doppel-Wobber, or something similar.
Translated on 31-08-2026, 6:14.
Post18-08-2009, 7:21    Subject: RKA Retrofit for 1K0 907 379 AC Quote
dieselmartin wrote:
I vaguely remember that in golf, it's not about _setting_ a bit, but rather _clearing_ it, meaning taking something away.
You're absolutely right, Martin!
Translated on 31-08-2026, 6:15.
Post18-08-2009, 10:46    Subject: RKA Retrofit for 1K0 907 379 AC Quote
Thanks to various online collections of links, I was also able to find the forum again.
http://www.team-dezent.at/anleitungen/Reifendruckkontrollsystem_Golf_V.pdf
Post24-01-2012, 23:03    Subject: RKA Retrofit for 1K0 907 379 AC Quote
WOW!!!
No switches!
Simply "re-encode" and then set the basic parameters to 042.
The golf club is currently diligently learning icon_wink.gif.
Translated on 31-08-2026, 6:16.
Post22-02-2012, 17:17    Subject: RKA Retrofit for 1K0 907 379 AC Quote
Not that great.
Is the TCU coded for "Caddy," and does it not want to know anything about the RKA icon_sad.gif?
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts FSE Premium Retrofit for Passat, Golf, Tiguan Troubleshooting & Guides
No new posts Retrofit GRA for 9N SDI Polo Diesel Engine Technology
No new posts Retrofitting MFA to the Sharan Diesel Engine Technology
No new posts GRA installation on the Passat 35i TDI 1Z: Steering wheel... Diesel Engine Technology
No new posts Retrofitting ESD/ASR for Audi A4 Diesel Engine Technology
