Alpin Tuning Box: Performance Upgrade
Mitgliedsname00
Post01-08-2003, 8:44    Subject: Alpin Tuning Box: Performance Upgrade Quote
Okay, according to my estimates, the tdi box from Alpin is wired as follows:
Connector from vehicle to SubD connector on the tuning box.
Pin 2 -> Pin 8
Pin 3 to Pin 7.
Pin 4 to Pin 5.
Pin 5 to Pin 1.
and from pin 2 (Sub D) to the mass airflow sensor - the question is, which pin is that?
connected are the following: donor, control slide valve assembly (2+3), temperature sensor (4), voltage + (5).
If someone can tell me where to connect it to the LMM, I'll give it a try.
Thank you very much.
Translated on 10-09-2026, 18:12.
Post01-08-2003, 10:27    Subject: Alpin Tuning Box: Performance Upgrade Quote
/viewtopic.php?t=1691&highlight=pin assignment+MAF
According to the wiring diagram, the 10-pin connector is located on the ESP.
Pin 8: N109, fuel shut-off valve.
Pin 9: N108, valve for injection start.
Pin 10: N108, valve for injection start.
My private message to you was therefore incorrect, sorry.
Translated on 10-09-2026, 18:14.
Mitgliedsname00
Post01-08-2003, 11:03    Subject: Alpin Tuning Box: Performance Upgrade Quote
OK, that should help me.
Just for information - I have an 8-pin connector in my Audi A4 with a 90 horsepower engine.
'However, it appears that the connections are the same up to pin 7. The mentioned pins for the power-off function are located on a 3-pin connector, and pin 8 is free on my device.'
Let's see how long it lasts.
Translated on 10-09-2026, 18:15.
No new posts Alpin Steuergerät MP10 Diesel Engine Technology
No new posts Alpin Box setup for Mazda Diesel Engine Technology
No new posts Speed-Buster 2 Installation Guide / Alpine Box works! Diesel Engine Technology
No new posts Winterreifen: Michelin Alpin A4 or Dunlop WinterSport 4D? Transmission, Chassis, Body & Interior
