Full engine power only from 3300 RPM in 1st gear
Svente68
Post03-08-2003, 20:25    Subject: Full engine power only from 3300 RPM in 1st gear Quote
I'm having a small problem with my Golf 3, manufactured in 1996, with 292,000 km on the odometer and 90 horsepower.
After the engine starts, I have no power available. It takes about 1 km to accelerate to 50 km/h. Only at 3300 RPM does the boost kick in, and then I have full engine power. I can then continue driving normally until the next engine start. What could be the problem? Could it be the mass airflow sensor (MAF)? Where exactly is it located?
You're very welcome, Svente68.
Post03-08-2003, 21:35    Subject: Re: Full engine power only from 3300 RPM on 1Z engine Quote
Svente68 wrote:
I need about 1 km to accelerate to 50 km/h. The cork doesn't pop out until 3300 RPM, and then I have full engine power available. I can then continue driving normally until the next engine start. What problem do I have here? Could it be the MAF sensor? Where is it exactly located?
Here you can find a large number of technical articles that answer most of the basic questions.
Simply click on the link in the gallery above, and you will find information about the LMM.
Okay, I'm ready. Please provide the German text you want me to translate.
So, first, do some research on that topic (and possibly in other related articles), and if you get stuck, feel free to ask more questions here.
It seems to me that your problem isn't caused by the LMM (lambda sensor), but rather by a lack of boost pressure due to a stuck turbocharger mechanism, or the usual suspect: the boost pressure control valve.
No new posts TDI V6: Documenting Engine Power Loss Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Engine Problems: Low Power & Error Code 00553 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Volle Einspritzmenge bei Teilgas ? Diesel Engine Technology
No new posts Engine Power & RPM: Explained Simply Diesel Engine Technology
No new posts Question about engine power Diesel Engine Technology
No new posts Brake Performance and Engine Power Transmission, Chassis, Body & Interior
