VAG-COM Interface Issues: Troubleshooting Guide
StpDiesel
Post30-07-2003, 17:31    Subject: VAG-COM Interface Issues: Troubleshooting Guide Quote
Hello everyone,
I recently bought an OBD II ISO interface on eBay with the intention of using it with VCDS (Vag-Com) on my G4 ALH.
Connected according to the instructions - the device is recognized as such by VAG-Com - but unfortunately, I cannot access the most important control units.
It only works with the instruments, Climatronic system, radio, and central locking.
My question to everyone:
Does anyone recognize this device? And if so, can anyone guess why it's not working properly for me, or only working partially?
http://www.kiedaisch4u.de/TDI/picts/interface_1.jpg
http://www.kiedaisch4u.de/TDI/picts/interface_2.jpg
Greetings.
Translated on 11-10-2026, 22:01.
Post30-07-2003, 19:37    Subject: VAG-COM Interface Issues: Troubleshooting Guide Quote
StpDiesel wrote:
The device is recognized by VAG-Com, but unfortunately, I cannot access the most important control units.
It only works with instruments, Climatronic, radio, and central locking.
Hi.
I'm not familiar with that component, and all I can say about your problems is that the thing probably works in principle, but likely only just barely, otherwise everyone would be able to connect to it.
The cause could also be related to the computer itself; this diagnostic article offers some tips to investigate the issue further.
And there's adapter test software available for download, which you can use to roughly check the transmission properties.
Good luck - and possibly also with trying to get support from the seller. . . icon_sad.gif
Translated on 11-10-2026, 22:03.
StpDiesel
Post31-07-2003, 9:43    Subject: VAG-COM Interface Issues: Troubleshooting Guide Quote
Hi.
Thank you for the quick response - I'll try it out with the adapter testing software.
Good luck - and hopefully you'll also be successful in trying to get support from the seller.
I highly doubt I'll get any support from the seller.
Best regards, Stp.
Translated on 11-10-2026, 22:04.
Post31-07-2003, 15:30    Subject: Software Update: Latest Version & Features Quote
Hi.
Your case prompted me to add more information to the adapter article -> specifically, the "VAGCOM Bugs" section.
It might be too late for you in some cases, but hopefully it will still be helpful.
Translated on 11-10-2026, 22:05.
andi
Post05-08-2003, 2:30    Subject: VAG-COM Interface Issues: Troubleshooting Guide Quote
Look at this, another one with the Ics (integrated circuit) chips sanded down. It seems to be a common trend, and even some well-known appliance manufacturers are doing it.
Despite that, the MAX232 chip can be identified on the right side by the four electrolytic capacitors.
It seems to have similarities with Miks adapters, so the 7404 might be on the left.
Translated on 11-10-2026, 22:06.
No new posts VCDS Interface for 24V systems On-Board Diagnostics (OBD)
No new posts CAN Interface RKS+CAN & SUB-D9 Cable On-Board Diagnostics (OBD)
No new posts VAG Interface: Where to Connect? On-Board Diagnostics (OBD)
No new posts CAN USB Interface: Troubleshooting & Repair On-Board Diagnostics (OBD)
